Time for battery replacement
Old Jun 11, 2011 | 01:29 PM
sachal007's Avatar
My Ride: BMW E-60 530I
So after 6 years i think its time to replace my battery...
i called few places and they recommended interstate batteries vs. OEM. They claim you get the same results and interstate is more cost effective.
i found a place down in san jose who deals with primarily BMW and spoke with JOE, he said they can install and program the battery for $220 (parts and labor)
I think the oem battery alond is $200 or $250 plus labor..
what do you guys think?
this is the battery
Product ID: MTP-48/H6
Amps: 965
Cranking Amps: 965
Cold Cranking Amps: 770
Voltage: 12
Pro-rata Warranty: 85
Weight: 40.8
Width: 6.89
Length: 10.94
Height: 7.48
MEGA-TRON PLUS - 85 MONTHS - 770 CCA
http://www.interstatebatteries.com/cs_eStore/Products/RT/PID-MTP-48~H6(Automotive+Truck).aspx?dsNavigation=Ns%7epro duct+Type%7c101%7c1%7c%2cN%7e21-4294493536-4294493520-2147384879&Title=Mega-Tron+Plus+-+85+Months+-+770+CCA
Old Jun 11, 2011 | 02:18 PM
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
AGM Battery same as latest BMW AGM-battery part# 61 21 7 594 976 $300+
Old Jun 11, 2011 | 03:38 PM
sachal007's Avatar
joe according to their website they recommend:
Manufacturer: DEKA
Part Number: 9AGM48
Description: Std Automotive Battery
Battery Gasses Need to be Vented to Outside ; 70 Month Warranty ; 760;CCA ; 1 Per Veh; Years:2006-2007; Per Car Qty:1;
Batteries
would getting the one u recommended with higher CCA would make any difference?
Old Jun 11, 2011 | 04:49 PM
luigi524td's Avatar
I'm told that AGM-type batteries cannot be properly registered on some e60's (early 2007 and older).
Old Nov 30, 2011 | 03:31 PM
midair's Avatar
Just had the AGM BWM battery 61-217-594-976 installed under warranty in a 2008 528i.
Let's hope this one last longer than the OEM; 3.5 years. I found the following specs for this new battery on a different forum:
BCI Group Size = 49
Din Size = H8
Voltage = 12
Cold Cranking Amps at 0 degrees F = 900
Cranking Amps at 32 degrees F = 1,035
Reserve Charge = 180 minutes
20 hour Amp hour rate = 95
Type = AGM
Length = 15 9/16"
Width = 6 7/8"
Height = 7 1/2"
Old Nov 30, 2011 | 04:02 PM
sachal007's Avatar
did u buy it at the dealer?
Old Nov 30, 2011 | 04:51 PM
pukka's Avatar
My Ride: 2008 535i: (8/07 Build) Metallic Bronze, Beige NASCA Leather, Ventilated Seats, Sport Pkg, Cold Wxr Pkg, Logic-7 Sound, HUD, Night Vision, PDC, Split Rear Seats, NAV, Premium Pkg, Comfort Access, HD Radio, Sport Auto Trans Current mods: M-Aero Kit, JB4, Motorcepts 6000k HID Foglamps Umnitza ICE-Lite 10w LED 6000k AE's 1992 Camaro RS: Fully Restored w/Custom Interior, 5.0L V8, T-tops, OEM Z28 Foglamps, Inst Cluster, & Spoiler, Custom Sound, Too many engine mods to list
this is the battery
Amps: 965
Cranking Amps: 965
Voltage: 12
Weight: 40.8
Width: 6.89
Length: 10.94
Height: 7.48
That battery will be too small and not fit correctly in your battery tray. You will also have to fabricate a vent tube extension since the tube in the car won't reach.
You should check the battery specs for your MY on realoem. My car required an 850CCA battery. Another member posted a terrific thread in the DIY section. Took his advice and got the Duralast 95R-DLG at Auto Zone for $170 installed - perfect fit. Found an indy that did the coding for $50 and have been running fine since.
Old Nov 30, 2011 | 06:00 PM
mbawazir's Avatar
My Ride: Titanum Grey 525i 2004 Black 328i 2008 2008 E70 X5
the link does not work but what I see its Interstate battery, right? if so, I replaced my battery few months ago with intesrstate, I think the size written on the battery is 93. the car runs great no issue with it. go for it and save money and no worries coz interstate batteries come with 5 year warranty
Awest91
Sep 17, 2022 11:05 PM
DavaiLave
Aug 2, 2022 02:16 AM
Kasmo
May 7, 2019 03:30 AM
BMW565
Nov 6, 2017 06:03 PM
