Time Attack Wheels and car shaking.....
I recently purchased and installed the Time Attack 19" with Front 245/35/19 and Rears 275/30/19 with Nitto555 and I'm just not that happy with them... I'm not sure what's wrong or what happened but when I'm hitting like 60-70 on a slight turn on the freeway it feels like the car is unstable. One time I was heading to vegas with 2 other people in the car and it hits speeds of 60-70 the steering wheel will shake alot . Brought it back to the tire shop and found out that he forgot to put on the hub rings. He put them but still feels off..... do I need to get an alignment or am I missing something...??
TIA
TIA
Originally Posted by NeRwEEzy' post='928866' date='Jun 30 2009, 04:01 PM
hub rings should do it. if the problem persists, make sure the wheels are properly balanced and an alignment is recommended.
It's balanced but have not taken it to get it aligned.. i'll prolly do it in a bit and see how it goes..
Originally Posted by radzM550i' post='928873' date='Jun 30 2009, 04:05 PM
It seems like vibration is a common problem for those kinds of wheels!
Originally Posted by speakerboxxz' post='928877' date='Jun 30 2009, 05:08 PM
Well it have 19" Time Attack for sale..haha.. anyone interested.....
My Ride: Bmw 530d 2004
I tell my story short.
Two years ago I bought 18" M166 replicas for my E60 and put Kumho Ecsta SPT KU31 245/40 R18 on them. The wheel shop forgot to put hub rings --> Shaking
They put hub rings on --> better, but still shaking
Another tire balance in other shop --> still better, but some vibration remained
Went back to this other shop, another tire balance with extreme care --> appeared that two of tires were out of round
Replaced these two tires under warranty, rebalance again and custom made hub rings for every wheel --> NO VIBRATION!
Just to give a hint what can be wrong with your wheels and/or tires...
road force balancing is key. also when you find a shop that does it make sure you watch them do it. Some shops will allow it to be off .5, but make sure they zero out your wheels on the machine.
Also you might want to look into getting different hub rings. i had the crappy metal ones and they sucked ass. I bought new ones off ebay for 10 dollars and they solved my problem! If you want a link to my auction pm me and i will dig through my old auctions and find it for you! Hope you get everything figured out!
