tilt wheel question
Hello members just join up first question i have a 2008 550i m sport does this car have the function when you turn the car off the sterring rasies to the top so you you can exit easy? thanks greg
Yes. I'm not totally sure, but I think you can activate it in IDrive by pressing menu, then pressing down on the controller and going to settings>vehicle...or something like that
Edit: I'm wrong, I don't think there is a way to turn it on and off. Something I read is to move the wheel all the way up until it stops. Then keep hitting the button a couple of times to make it move a bit further up. Next move the wheel all the way down and repeat hitting the button a couple of times to make it move down a bit more. This procedure supposedly resets the exit feature. If that doesn't work, try resetting one of your seat memory positions. That has worked for some. Good luck
My Ride: coilvers retrofits
Model Year: 2001 and 2011
when i turn my car off, it rises to the top. then when i turn it on goes back to the setting i had it on for driving. thought all e60 did it.
My Ride: 2007 LCI 535SE Auto,Mtech Bodykit and Rear Spoiler, Blufin Chipped, 124 alloys,Space grey, Folding Mirrors, Black leather, Adaptive headlights, Pro nav, Bluetooth,Logic 7,Comfort access, USB, Adaptive Cruise, Lane Departure, Acoustic Solutions DAB, love my car!
Retired-2003 530SE, 124 alloys,Titan silver, Black leather, Adaptive headlights, Business nav, Mtech Bodykit & Rear Spoiler,-petrol with LPG
If you have memory seats, you have this function- it can be turned on in Idrive settings menue. If no memory seats, you dont have, as far as I know
My Ride: 2005 545i (SMG)
Titanium Gray
Black Interior, Anthracite Trim
M-tech kit
Sport Package
Premium Sound
Satellite Radio
Active Cruise
Comfort Seats
Navigation
Folding rear seats
My car has this feature. 2005 545i with Comfort Seats.
When ignition turned off, the steering column raises to the top position. It lowers then ignition started again.
I must have a problem with my tilt it won't even raise up or down at all even when your in the car it will tilt out and in but not up or down need to get it look at i figure thanks guys for all your help it means a lot to me
Let me get this straight, even with the car on, moving it manually with switch up or down didn't work? But moving it in and out did? Could it be a bad switch maybe?
Here's what I did: Start the car, move the wheel all the way up then all the way down (if you can't get this to happen then you're SOL, if you can then continue reading). Center it. Now move all the way in and then all the way out. Then back in approximately half way. Turn car off.
It should move. At least mine did and for good measure I resetted my memory. For some reason my wheel was just stuck in one position. When the wifey uses her key the seat and mirrors would adjust but never the wheel and when I used mine, same thing. It now moves out of the way when I leave the car. Hope this helps.
