ticking/clicking noise
Old 12-29-2009, 08:20 AM
  #21
Fuzzmon's Avatar
Originally Posted by ziad' post='787822' date='Feb 8 2009, 11:21 AM
I think I have the same problem on my 04 525i.
When I start up the car, any time of the day, whether it's cold or warm, when the it's idling my engine sounds like a diesel engine, or like an engine that's giving out, but as soon as I step on the throttle, the sound goes away. My guess is, it's one of the pulleys (AC, Water pump...etc).
Any suggestions ???
I've got the same issue on my 04' 545. A loud rattling sound from the right front area of the engine bay when the car is at idle. I have the 6-speed manual and the noise increases when the clutch is being engaged and the engine is loaded, then disappears once the clutch is fully engaged and the car is moving. Dealer told me it was the ac compressor and suggested replacing the entire unit. Wondering if just the ac pully can be replaced? Did you ever solve your problem?
Old 12-30-2009, 10:10 AM
  #22
henny's Avatar
My Ride: 530i
I'm not sure if it's the same on an 8 cyl but the a/c comp has it's own belt on the inline 6. If it's setup the same, take off the a/c belt. If the noise is gone you know it's the a/c comp. If it's still there, it's something else.
If you do find the a/c is causing the noise, you may be able to replace the a/c clutch-pulley assembly instead of replacing the the whole compressor.
Good luck
Old 01-01-2010, 05:51 PM
  #23
APWTE6O's Avatar
Good luck
i know on my car it's definately the a/c compressor it's like a rattle chatter noise at idle when i give it some gas it will disapear and come right back until it's fully warmed up which is about 20mins or so doesn't matter if a/c is on or not Took it to the dealer they replace some kind of tensioner/pulley assembly which did not solve the problem one bit my car just hit 100k my CPO is up
Old 01-02-2010, 05:42 PM
  #24
joebaggg's Avatar
My Ride: 2013 535i xDrive AW/Black M-kit
my car has been at the dealer for 2 weeks, its the lift something or other needs to be tightened in the engine... sorry i dont know much about engines, he said lift something... haha ill get the car back this week and post back... maybe someone knows what im talking about. he also said theres a grey area and theyr not covered under the extended warranty, i just made the cut off so id have them check it out before its too late.
Old 01-03-2010, 05:21 AM
  #25
Krisbiker2's Avatar
My Ride: 2007 LCI 535SE Auto,Mtech Bodykit and Rear Spoiler, Blufin Chipped, 124 alloys,Space grey, Folding Mirrors, Black leather, Adaptive headlights, Pro nav, Bluetooth,Logic 7,Comfort access, USB, Adaptive Cruise, Lane Departure, Acoustic Solutions DAB, love my car! Retired-2003 530SE, 124 alloys,Titan silver, Black leather, Adaptive headlights, Business nav, Mtech Bodykit & Rear Spoiler,-petrol with LPG
Could be hydralic tappets/(us=lifters)- oil can drain out, then takes up to 0.5 hr of driving to pump up fully again. I had same problem may years ago on old sdi rover. Dont know if changing them helps- earlier post suggests not, although it may be the dealer in that case did not replace other worn parts as well.
Old 01-03-2010, 01:18 PM
  #26
joebaggg's Avatar
yup that sounds about right... thank god it was covered, i wonder what "grey arrea" they were talking about in the warranty
PakiBeamer
12-09-2016 04:40 AM
LILBZ3
09-27-2015 08:06 PM
mohebmhanna
09-21-2015 05:08 PM
rmendoza.2611
09-11-2015 10:00 AM
snoop
09-09-2015 08:47 AM
Quick Reply: ticking/clicking noise
