Thud/Jerk after Starting Engine
Old 09-23-2008, 05:46 PM
obrien2631's Avatar
I have an 08 535i and have noticed a "thud" and slight jerk in the drivetrain a split-second after starting the engine. Appears to mostly happen on cold starts. Has anyone here experienced the same thing? Is this normal?
Old 09-24-2008, 08:14 AM
cobradav's Avatar
It appears you may have this issue:
SI B 24 03 08
Automatic Transmission July 2008
Technical Service
This Service Information bulletin supersedes SI B24 03 08 dated June 2008.
(New) designates changes to this revision
SUBJECT
335i, 535i with N54 and 6HP19TU - Jolt and Delay when Pulling Away
MODEL
E90, E92, E93 (335i) with N54 and 6HP19TU from 12/06 up to 09/07
(New) E60, E61 (535i) with N54 and 6HP19TU from 03/07 up to 03/08
SITUATION
The customer may complain of a delayed engagement and a harsh jolt when accelerating from a stop.
The situation occurs only during the engine warm-up phase (cold engine), and can not be reproduced in the Sport Mode.
CAUSE
EGS software (unfavorable NIC ? Neutral Idle Control calibration)
SOLUTION
On a customer complaint basis only, check the vehicle's integration level.
(New) If the integration level is:
On E9x vehicles ? E89X-07-06-520 or lower
On E6x vehicles - E060-07-09-530 or lower
Reprogram and recode the complete vehicle with a current Progman version (target levels are E89X-07-09-518 or E060-08-03-510, respectively, for E9x and E6x vehicles).
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Defect Code: .... 24 00 33 98 00
Labor Operation:........Labor Allowance:............... Description:
61 00 801 ...................... 7 FRU ........................Programming coding modules without CAS
61 00 811........................8 FRU ..........................Programming coding modules including CAS
Old 09-24-2008, 08:57 AM
jcool10181's Avatar
I've heard that thud before but never really thought about it as a threat. Since there's an SIB for it, i might consider it if i want to get my software updated. This can be a good excuse to use. Although, i'm also hesitating to get my software updated since BMW might have a newer progman that will limit the car's performance. They do this to discourage tuning.
Old 09-24-2008, 11:03 AM
vegas1111's Avatar
Not sure if I have the same problem. Wrote about it once before. Mine has a thud right after starting enginge, and before ever engaging the automatic (2008 528). The 'thud' varies from slight, to so much that the vehicle jolts a little and sounds somewhat metallic, and it is coming from the transmission. I took it in and was told this "is normal", although I have never had a car do this. However, it was so 'normal', that a software fix was coming out in September. Why would there be a fix if it was normal?
More recently, I have noticed that when at a red light, that when you take your foot off the brake, that the vehicle sometimes does not move forward. It just sits there like it is neutral. Always before, and in every other case, the vehicle moves slightly forward when releasing the brake. This happens mostly at the first couple of lights after leaving home, than back to normal.
I will call back after Sept., but I am concerned there is something amiss somewhere, and better found under warrenty.
Old 09-24-2008, 01:21 PM
bigbadbull's Avatar
My Ride: 2010 VW Passat Wagon 2.0l Tsi Grey/Grey Budapest 18" Lost to HPFP issues: 08 535i sport pkg Lost to Dreaded E61 Sun roof leaks: 07 E61 530Xi
It could have some thing to do with the Hill hold to.
Have you tried the 25sec transmission reset yet? There are threads all over the board about it.
For those considering a software update you may want to think twice about it on a 535i. V: 29.1+ of the DMS software with the N54 motor has some issues
http://www.e90post.com/forums/showthread.php?t=147781
it's up to about page 81 now.
Lag city is all I got to say. If you can avoid the DMS update till BMWNA resolves the new issue they have caused, do so it's in your best intrest.
Old 09-27-2008, 08:56 PM
obrien2631's Avatar
This is exactly what my 535 is doing. I noticed that if it was parked such that the parking gear is keeping the car from moving (as opposed to the emergency brake) the thud is almost unnoticeable upon start. Still debating whether or not to bring it in to the dealer to get the software updated if that indeed fixes the problem because of the negative aspects of the update that I have read on here. However, the thud/jerk can't be good for the car. Have you had the software update done to your car?
Old 09-27-2008, 08:58 PM
obrien2631's Avatar
Thanks for the info. I did try the 25sec transmission reset after reading your post but unfortunately the thud/jerk is still there.
Old 11-04-2008, 12:07 AM
bmgg's Avatar
I checked with Bimmer for this SIB, but in fact mine 05 545i has a different engine. Do you know a similar SIB for 05 545i? Thanks!!
Old 11-04-2008, 05:13 AM
cobradav's Avatar
Nothing specific for the V8 versions 545 or 550 yet.
Old 11-04-2008, 09:27 AM
flyingpuck's Avatar
Sounds as if you may have backed over a jerk!!
Quick Reply: Thud/Jerk after Starting Engine
