They found the oil leak(s)....
#21
My Ride: 2005 545i Sport 6MT
I noticed that my valve cover gaskets are leaking, but not crazy yet...i also noticed a "sweating" from the timing cover on the passenger side as well...
67k miles here.
67k miles here.
#22
Originally Posted by kxmills' post='1095804' date='Jan 22 2010, 02:55 PM
I just had the same thing done to my 545. Valve cover and timing chain cover gaskets. While the engine was out of the car I replaced the water pump and clutch too.
#23
My Ride: '04 545i, Silver Gray-Black Dakota, Cold pkg, Prem. Sound, Sport pkg, Nav, Voice Activation
Dang I should feel good with 121K miles and no gaskets replaced. Only CCC, window motors, coolant temp. sensor & vent hose, passenger restraint sensor & seat cover. Just annoying crap, not engine, trans, or drive train thank god.
Let's face it, German cars do require service but still not as much as a Ferrari! ha..ha..
#24
Originally Posted by tallers' post='1095733' date='Jan 22 2010, 02:05 PM
I struggle understanding a BMW having a valve cover gasket leak with less than 50K miles. WTF? Has BMW been benchmarking with companies like GM, Dodge, and Fiat?
Those of you with leaky valve covers - be sure you don't have oil in the spark plug pockets, it can short out the coil, create misfires and damage your cat converters.
#25
Originally Posted by WillD' post='1096055' date='Jan 22 2010, 10:22 PM
I have a BMW because I enjoy the way it rides & performs, but reliability is not in the same league as the more reliable marques, which lately has included GM. Piously dumping on other automakers when in reality they do many things better isn't a fair assessment. Almost every automaker successfully employs plastic for rocker covers, and it's not just about cost but weight, too. My GM engine doesn't leak oil, but my '99 740 with metal valve covers did at 50k miles; and now this week I also had the PCV system changed on my '05 530i. Fortunately it's CPO, covered all but $50, same as OP. Dealer also replaced belt tensioner which was shot, along with belt and associated parts. Very happy it's a CPO, and 15 months to go before it expires.
Warranty or not, CPO or not, these cars should not have these issues at the price they cost. GM would be more than happy to tell BMW how hard it will be to repair a poor quality reputation.
#26
My Ride: 2005 Jet Black 545i w/ sport pkg, nav, HUD
UPDATE: the adjuster inspected the car on friday and would only approve the valve cover gaskets. he said there was too much oil coming from the valve cover gaskets and that may be leaking onto the timing cover making it look like the timing cover gasket is leaking. He told the sa to change the valve gaskets and drive it a bit....and if oil leaks from the timing cover, then change the timing cover gasket. I guess it sounds pretty logical, and at least they are authorizing the work. I'll keep y'all updated.
who dat!!
will
who dat!!
will
#27
So they fixed replaced the valve cover gaskets and oil sensor, cleaned the engine, ran it and the timing cover gasket is leaking. Now I have to wait for the adjuster to come out again and verify that the tc gasket is leaking and authorize the repair. Whew!
who dat!
will
who dat!
will
#28
I had the exact same issues with my 2004 545. So for they have replaced the valve cover gaskets, Tranny oil pan, rear diff seals, active stabilizer bar, timing case cover, vaccum pump and oil pressure switch....oh yeah and the coolant resevoir and vent pipe. My car has 49k on the clock. So far the extended warranty from Mercury has covered everything for a cost of $6,500!!! The warranty cost me about $3,000.
#29
UPDATE: Adjuster came out again and authorized the timing cover gasket replacement. At that time they notice oil is still leaking from a valve cover which the tech now says is warped. He approves a new valve cover. Hopefully it will be ready tomorrow. I love and miss my 545, but this is ridiculous for a $60k car!
Who Dat!
will
Who Dat!
will
#30
My Ride: E90 M3
Model Year: 2011
This is Bob Smith from the NFL. You are using copyrighted material we own and we demand you stop using the "Who Dat!" cheer in your emails. Our legal department will be in touch shortly...
Hang in there Will, hopefully you'll have the car back for the weekend, good as new. You going to Miami?
