Tension Strut Bush
My Ride: E60 M54
Model Year: 525i 2004
Guys, I was wondering if it is possible to take out the tension strut (front left and right) without removing the controller arm? So I can replace the bushes.
I have read that the suspension needs to be held and what not to take the tension strut out for bush replacement. Any help is welcome.
P.S. I am aware I would need a press tool to actually remove the bush out of the strut and back in.
Go to the DIY section, has been covered.
I assume you are not talking about a strut but rather the thrust arm and the thrust arm bushings? You have to use the correct terminology here in order to get a good/complete answer
derooster
09-22-2015 10:10 AM
