Temperature Control Question
My Ride: 2015 535D M Sport
Originally Posted by gwf545' post='237480' date='Feb 9 2006, 04:03 PM
I am not so sure it is "silly gadget overkill". The whole point of iDrive was to remove the knob-button-dial clutter from the cockpit. It would look more like a 777 than car if they didn't do it. The vent temp. setting is just one less knob on the dash to contend with.
Just checking,
Ray Hull
If you like to change the offset a lot, then I take your point, but you can use voice commands as a shortcut to get there.
My experience with the e39 thumwheel was that it never "held" the desired input and as such you always had to fart about with it to maintain the required air temp. In the e60 the offset is maintained perfectly.
[/quote]
Agreed, except that it's not quite one time set and forget. I change it maybe two or three times a month simply out of personal preference. I think mostly it has to do whether the sun is on me or not. That said, it's still pretty simple to do using the short-cuts.
UltimatePeter
DIY: Do It Yourself
05-12-2015 08:00 AM
