Taking Some Time To Heat Up...
My Ride: 2005 545i E60 Orient Blau Metallic
Premium, NAV, Winter Package, Heads Up Display, Logic 7 Audio, AngeliBright Upgrade [White], M5 Body Kit, M Embroidered Seats
So its getting colder up here in the Northeast and I note that it takes a lot longer for the white dial to slide all the way to the right than before. Theres no issue with starting the motor, just takes almost ten minutes for the white dial to go from the 4.5K spot on the RPM meter to the 6.5K area...
Anyone else have this issue????????????????????????????????????????? Does this need to get checked out??????????????????????????????
My Ride: 04 545i - Titanium Silver/Black, Sport pkg, Comfort Seats w/ Lumbar, Premium Sound, power rear sunshade, Adaptive Xenon Headlights, Steptronic, Park Distance Control, Fold down rear seats w/ski bag, Aux jack, 6-disk changer, puddle lamps...
Engine: Custom Remus cat-back exhaust w/chrome square tips, K&N Air Filter, Charcoal Filter Removed, Sprint Booster :-), 50/50 mix of 91+100 Octane, EuroRev ECU Remap (coming soon lol), Dinan High-Flow Throttle Body (coming soon...maybe lol)
Interior: Portable Sirius Stilletto 100 w/car kit, Garmin Nuvi 680 mounted below rear-view mirror, LCI-style I-drive knob, Dark Poplar Center Dashboard Trim.
Exterior: E60 forum clings, 5% rear tint, ACS roof spoiler (painted black for distinct look against limo tint), ACS trunk spoiler, ACS add-on front spoiler and rear apron (awaiting installation), "18 Black Staggered BeBeS Style OER (emergency replacement for cracked sport 124 rims), black kidney grill, white accessory lighting (including license and trunk lamps), Angel-eye upgrade, AIB xenon-matched fog lamps, AIB V3's on order, red rear reflectors
Originally Posted by subarashi' post='696027' date='Oct 17 2008, 05:48 PM
So its getting colder up here in the Northeast and I note that it takes a lot longer for the white dial to slide all the way to the right than before. Theres no issue with starting the motor, just takes almost ten minutes for the white dial to go from the 4.5K spot on the RPM meter to the 9K area...
Colder air = longer warmup times. Are you driving the car immediately after starting, or are you allowing it to idle until warmed up? Are you blasting the heater or is it off? If the heater is off, you drive immediately after starting, and you find it's taken longer than it ever has at the same temperature, a visit to the dealer wouldn't hurt. However, with the myriad of sensors and monitors, the car should report if warmup is longer than normal based on air intake temperatures, coolant temps at startup, and the like.
Adv Logic:
So I am driving off immediately, no idling [per the manual]. I do not blast the heater but wait a while before turning it on unless the mornings are really cold. Funny part is it didn't do this last winter, as far as I remember. Seems to be taking longer, and we're only hovering around the 40s in the mornings -- worried about whatll happen when it REALLY gets cold!
My Ride: '06 550i
'84 Nissan S12 Turbo
So the lower on the rpm gauge the tick marks are the colder the engine is? Is there an indicator if the engine starts to overheat?
Originally Posted by ktlocklear' post='696047' date='Oct 17 2008, 08:40 PM
Ahhh, so thats what those little white tick marks are for.....learn something new everyday
Originally Posted by DrLev99' post='696208' date='Oct 17 2008, 11:20 PM
Really, Mr. Obvious?
To the OP, the only major componant I can think of that would cause a hypothermic condition during the warm-up phase would be a thermostat stuck 'open'. Keep us posted (perhaps a video of the condition?)
All:
So I talked to the dealer and it appears that perhaps a heating element failure/coil beginning to die could cause this issue. On my wife's 2007 X5, the heating takes SECONDS literally, in the same ambient temperature. While I recognize these are different engines, obviously some of the heating technology is shared across models...
He reccs I bring it in for a diagnostic on the heating element which I will probably do later this week. It didnt take this long to heat last year, even when the temp was in the teens. Stay tuned and if you've also got this issue - chime in with your experiences...
rackhacker9275
May 11, 2018 04:05 AM
