synch needed after replacement of key or antenna amp board?
My Ride: 2006 530xi touring
Engine: 3 liter
I have 2 questions.
1) After you replace the antenna amplifier board, is there a synchronization process required to synch the board to the key's frequencies and codes specific to your car? If so, what are the synchronization steps?
2) After you go to the dealer and buy a $300 key fob. Is there a synchronization process required to register a new key fob to the car?
Thanks
Thanks
No to both questions.
When you receive the new key, insert the key in the ignition and start the car, as you'd with any other key. That's it.
After replacing the diversity amp, no need to sync/reset anything.
BrandonSS
03-30-2015 09:48 AM
Brooklyn88
03-21-2015 06:23 PM
