Switching ON/OFF for dummies :-)
Old 12-14-2005, 01:09 AM
LukeV's Avatar
Well, guys, I know it is an odd problem but all of your opinions are well accepted.
Just a point: should I follow the "always stay on" option on my 40K tube monoblocks, I would spend half that amount on tubes in about two years.
Cheerio
Luca
Old 12-14-2005, 01:15 AM
browellm's Avatar
Cheerio
Luca
I actually think it would make little difference. See cobradav's post above.
Old 12-14-2005, 01:24 AM
LukeV's Avatar
Well, my Hickok Tube tester assumes the contrary <_<
OT MODE ON
Well, let me be precise: it is certainly sure that switching on and off a "tube driven equpment " several times could be more dangerous and "lifespan shortening" than leaving it on 24 hours per day but we have to remember that lifespan of high end audio equipment valves is fixed at few thousend hours more or less which means that, should I leave my amps on 24h per day, I should change the valve kit three times a year.
Obviously, these are just opinions: audiophile world is always in struggle.
OT MODE OFF
Luca
Old 12-14-2005, 06:39 AM
cobradav's Avatar
Sorry I should have been more clear on the "HIGH" power systems I was referring to. We left the systems low power on all the time, but only used the HIGH power portions when required (actual satellite or missile track, or calibration target track). Yes we did conserve use of the actual HIGH power but kept filaments on and tubes warm. How well I know the need to conserve the high power tubes as they were about $50k to $350k each depending on complexity of and number of the tunable cavities.
Old 12-14-2005, 07:25 AM
katheikia's Avatar
My Ride: 2006 550 SMG
When I press the mute button sound goes off but when I re-press it 10 mins later the CD has kept playing and it comes on at a new song. Is this normal?
Old 12-14-2005, 07:48 AM
Ray Hull's Avatar
My Ride: '04 545iS 6 spd, bought new via eBay, 11/05; Blk/Gry, Cold, L7, PDC, BMW Rear seatcover for pets. First "Bumwa" was a new 1971 2002. High performance 5s since 1987. Beamer motorcycles too, currently on an 07 BMW K1200 GT; also a Moto Guzzi 1000 SP III.
While searching for something else, I came across this service bulletin; notice the last "complaint" (that I copied, list went on longer):
SI B 61 14 03
General Electrical Systems October 2005
Technical Service
This Service Information bulletin supersedes S.I. B61 14 03 dated September 2005.
designates changes to this revision
SUBJECT
Software Errors Corrected with CIP
MODEL
E60, E61 (5 Series)
E63, E64 (6 Series)
SITUATION
Customer may complain of the following:
The following software errors were corrected with the release of CIP 19.02.00 (Target data Status E060-05-09-530).
No Software corrections included in this version of CIP
The following software errors were corrected with the release of CIP 19.01.00 (Target data Status E060-05-09-530).
Increased AL (Active Front Steering) sensitivity at low speeds under 30 mph.
"High Battery Drain Message" in CID (Central Information Display). Refer to SI B61 06 05.
CCC (Car Communication Computer) equipped vehicles with telephone, call fails when dialed using linked sequence ("p" for pause) stored phone numbers. Refer to SI B84 18 05.
The audio keeps playing if the vehicle is switched off for up to 3 minutes (until vehicle enters sleep mode). The audio cannot be switched off with the rotary knob. Only vehicles with CCC (Car Communication Computer) are affected.
Ray Hull
Old 12-14-2005, 02:08 PM
browellm's Avatar
Hmm, this was a problem with the older s/w, was fixed around V12.x if I remember correctly. As you have a 550i, you must be on at least v18/19. Hope they haven't reintroduced this bug.
Old 12-14-2005, 06:10 PM
cobradav's Avatar
[/quote]
Yep similar but slightly different problem fixed early this year.
The following software errors were corrected with the release of CIP 16.1 (Target data Status E060-05-03-520).
Audio off or mute mode is not stored on CCC vehicles after sleep mode. Affected vehicles: E60 (5 Series with CCC), E63/E64 (6 Series). Refer to SM B65 228 04.
Vman33
03-14-2022 04:43 AM
Johnny B
E34/E28/E12 Discussion
12-25-2015 05:33 AM
Bogdan7
09-23-2015 11:40 AM
Bank$hot530
09-16-2015 01:28 PM
AndreasE60
E39 Discussion
09-10-2015 08:45 AM
Quick Reply: Switching ON/OFF for dummies :-)
