Swirl Flat Removal Perhaps?
My Ride: 2005 530d M Sport, Carbon Black, Black half leather
Does anyone know if my car should need its swirl flats removing. after abit of reading it seems some cars wont be effected by the problem. I have a 2005 530d M Sport. W Reg...
Also if i do need them removing does anyone know what size screw id need to block the hole and the best glue to keep it in with
I removed mine. I used a screw that is used on Ikea carcass kitchen units (I can hear the laughter). It's allmost like a grub screw but with a slight lip on it around the head. It's the screw used to fix the wall fitment brackets to the back of the cupboard. It also has a flat end on it so it doesn't protrude into the inlet void and they are very tight so no chance of them coming loose. I know it sounds like a bodge but they fit perfectly!
My Ride: Bmw 530d 2004
They are actual flaps that locate in the intake manifold. A vacuum pump controlles them.
There have been numerous failures, where the axle or the fastening of the flap has broken, and the swirl flap has been sucked into the cylinder ---> massive breakdown.
Epic;
Your car has the swirl flaps, but I'm pretty sure they are the "updated" model, with 0,5mm stronger axle (
![Nono](https://5series.net/forums/images/smilies/imported/nono.gif)
So, it is up to you what you want to do. I guess you have seen my DIY guide on a DIY section...
- Antti -
Thanks for the replys. i have seen your DIY yes and have given it to my friend who actualy works for BMW who is going to remove them for me today and tomorrow. got some araldite for fix the screws into place. that should be alright shouldnt it?
PelicanParts.com
07-09-2015 01:07 PM
