swirl flap removal
DPF block was around 55k miles. Considering mine was relatively low mileage, perhaps I too should have just invested in a new manifold.
Flaps on a brand new manifold are much less likely to fail though not totally fail safe.
By getting a new manifold, I guess you'll significantly reduce swirl flap failure risk and also keep your car in an original state.
I understand the F10 doesn't have swirl flaps. If they are such a great thing I wonder why BMW have stopped using them. You can't assume the designers got everything right. Look at the Nikasil block issue where BMW made 100,000's of cars with duff engines and the recent fragile wheel issues. Car are designed by people and what seems like a good idea at design time doesn't always pan out.
Deep in the menus is DIS you can request a forced regen and check when one was last done - I can't remember the exact path sorry.
If your thermostats were bad your car probably couldn't reach the criteria for a regen so you had some soot to burn off.
The DPF is a service item and is expected to be replaced, depending on the use the car gets this can happen early. Especially as the "standard" BMW driving profile is high mileage long journeys and under 7k miles a year is considered "extreme use".
I think swirl flap failure is rare, but if it happens to you you'll know about it! I'd rather not have the risk and if the DPF soots up earlier then I'll service it earlier - but I doubt it will.
Guest
Posts: n/a
BMW noticed a design fault and the original design was changed in late 2004 I think, since then failures have sprung up but when you put it into perspective vs amount of cars produced then it's a very small % persons have a choice 1)have a warranty 2)change the manifold at the dealer 3) bodge it by fitting blanking plates, with no R&D and performed outside the dealer network, may not only have long term concerns but may also invalidate your insurance, it's down to the owner but no amount of scaremongering on forums or websites will sway my judgment.
well ive just returned from the dealers with my new manifold,,and the swirl flaps are attached with two small screws!
i got the impression that there wouldnt be any ,just a solid plastic one piece swirl flap
anyhow fitting it on saturday with any luck
i dont know any torque values for tightening the manifold bolts,,,but ill work out how tight they are on when i remove them with my torque wrench
thanks again,cheers
I used to be a volvo truck mechanic back in the day. The only time we used a torque wrench was for the cylinder head and inner engine components. You can tell how tight things need to be by feel most of the time. Cmon guys
