swapping LM pins for lci light retrofit
My Ride: 2006 BMW 550i
reading this post from cwest: https://5series.net/forums/topic/112...st__p__1329614
however the bmw install pdf guide says all cars should swap pins.
![swapping LM pins for lci light retrofit-pins.jpg](https://5series.net/forums/attachments/e60-discussion-2/131025d1482364520t-swapping-lm-pins-lci-light-retrofit-pins.jpg)
am i reading something wrong? do all cars have to swap these pins, or cars before 3/05?
The Important Key to this Conversion is for Pre 3/2005 built E60's have to swap pins in the Light Module or els AE will not light up correctly.... That's the Key to your answer.
Re-Pin the LM for AE to work properly (Pre 3/2005 built E60)
- pin 25, GR/GN, to pin 63
- pin 40, GR/BL, to pin 11
all cars
socale39
09-05-2023 08:30 AM
Beemer
33
01-14-2019 05:13 AM
rizwan1377
04-05-2015 05:22 PM
