5Series.net - Forums
-   -   suspension getting harsher... (https://5series.net/forums/e60-discussion-2/suspension-getting-harsher-16976/)
Jeffs Oct 10, 2005 01:19 AM
My ride is becoming harsher. Is it because the tires are gettin bald?? Or do I need to see my dealer? I hate seeing them because it takes a week to even get an appointment wi the service manager... :help:
Gray Dog Oct 10, 2005 03:42 AM
[snapback]182080[/snapback]
The tires could be the problem.
FJPM Oct 10, 2005 03:54 AM
The heating-cooling cycles make the tyre harsher when they get old
Ralph-NL Oct 10, 2005 10:40 AM
What kind of suspension do you have? Normal or 'air' suspension
Jeffs Oct 10, 2005 12:53 PM
[snapback]182257[/snapback]
I have sport suspension...is there even an air suspension option in the 5?? I never knoew that
allenman Oct 10, 2005 12:55 PM
And why would your dealer have anything to do with replacing tires?
Get thee to a quality tire shoppe!
znod Oct 10, 2005 01:15 PM
Hi Jeffs:
Do you have the Dunlop run flats? If so, then maybe it is the Dunlops. If the wear in on the inside, then I'd go to your dealer and try to get them replaced. They will need to have less than 20K miles to be replaceable. Check out this thread and the one I refer to on its page 2.
Hormazd Oct 10, 2005 03:37 PM
Aside from the distinct possibility that your Dunlops are worn, you may have an Active suspension/dynamic drive problem. When cornering, dynamic drive raises the pressure to the struts to give us the flat cornering. This pressure is increased using the power steering pump. When operating optimally the pressure is released after the corner. In your case the pressure remains high.
I had this problem and after many days of diagnostics going back and forth between my deaker and BMWNA, they changed the power steering pump.
I first realized that I had this problem because I would hear a clunking noise when the car approached bumps at a certain angles. They determined that the noise went away when disconnecting the AS fuse. That is how they isolated the problem to the Active suspension.
