Suspension (best route to take)
My Ride: Sapphire black-stealth e60
Hi all
I have an air noise comin from my suspension at the front (drivers side) so have been lookin at coilovers. But when i went 2 my local bmw specialist he said on these cars make sure u buy oem parts. So wat do people think of there coilovers because im now not to sure wat to do. So how pleased are u guys with ur coilies or shall i stay oem???
Ps anyone in the manchester area that does work on these cars nd would like to help me in some areas im not that good with would appreciate that for some extra ca5h;-).
Thanks james
Thanks james
My Ride: 2005 545i Sport
BMW suspensions are very precise. The coil springs must be perfectly aligned on the strut (shock absorber) bases in order to align correctly. Even the rubber coil spring mounts needs precise location.
This is not your typical round coils spring fitted to a round shock base plate. The lower spring is a weird kind of oblong shape that must be fitted correctly. If you look at your OEM setup, you'll notice three painted dots on your coil spring and a notch in the lower strut spring base plate. All of this related to precise alignment
I'm not sure how precise the aftermarket stuff is.
The strut mount (I don't believe that Bilstein, KYB, etc even make a corresponding strut mount) is a ball bearing unit that will wear very quickly if the coil spring is not correctly/precisely mounted.
I don't know, I've been a big fan of Bilstein (Mercedes experience) so it's not a prejudice against them. Japanese stuff (KYB on a BMW; not going to do that. So, that leaves you with Boge/Sachs struts in my view. Replace your strut mount in the process.
You mess with anything (control arms, tie rods, strut) that mounts to the wheel hub assembly and you're going to need an alignment. Here in the states, BMW cost $130 to $150 w/o Sport suspension, with it ($230 - $299).
It's your call, there are plenty of folks on this forum that will state that KYB or Bilstein is the best way to go.
Ok ill do more homework thanks for the reply bro. im on abit of a budget atm hopefully i can get enough saved 2 buy the best only the best will do lol
My Ride: F10 M5
Model Year: 2013
Hi all
Thanks james
Thanks james
Hi mate im not lookin in2 gettin them just yet but will be soon.
Do u ship to the uk?
And do u have a privelist?
Thanks
Thanks
My Ride: 09 550i 6sp M-Tech. 18mm spacers rear, 8mm front. Dinan intake and Stage 2 tune. Tinted tails, M5 OEM lip spoiler.
08 Z4 3.0si Black on Black with Beige top. Removable hardtop. (Hers)
06 Volvo S60R Heavily Modded!! Gone and missed.
My Ride: F10 M5
Model Year: 2013
Vman33
03-14-2022 04:43 AM
bmwmonkey
08-17-2015 10:34 AM
PelicanParts.com
08-04-2015 01:34 PM
