Sunroof won't close
For some reason, my sunroof wont' close. When I pressed the latch switch to close the sunroof, it will go through the process of closing then it pop up (tilt) then come back down and stay open about 1/4 size. I don't why it won't stay stay close.
press the button to tilt up and keep holding it till it does the whole process. The sunroof will start to open and close. It will do an entire opening then close fully. When it is fully closed, you can remove your finger from the button. That way you would have done a reset to the sunroof and will work properly.
RCT
My Ride: G30 M550i
Model Year: 2018
Did you try initializing the sunroof?
Look here for more info:
https://5series.net/forums/gallery/i...g-the-sunroof/
I found this helpful
Sunroof Initialization BMW 5 Series E60 E61 https://wiki.bentleypublishers.com/x/AgBEB
My Ride: 2008 AW N52 with sports package & premium package; natural brown interior
MODs:
Orion V2s
3000K H8 Yellow Fogs
Matte Black Kidney Grills
20" Miro 111
Hankook V12 Tires
H&R Sport Springs
Special coding via Simon (dbl flash hazards, digital velocity, etc.)
LED Side Markers from Trinity Autosports
LED License Plate Lights from Trinity Autosports
Carbon Delete
BMC Air Filter
RPI Scoop
RPI GT Exhaust
Future MODs:
Mtech Kit
KW Variant 2 Coilovers
CIC Retrofit
Upgrade Audio System
Thank you so much. This is very helpful. I will try initializing my sunroof today.
