Sunroof leak
Old Nov 22, 2007 | 07:51 AM
pulserace2004's Avatar
My Ride: 2011 528i Sport/Premium/NAV
I've noticed recently that I had some spots and old stains on my ceiling and assumed it was just from dirt and dust from keeping my sunroof open so often.
So....I went through a drive-thru car wash yesterday, and upon exiting the facility, I noticed there were large wet spots on my interior ceiling, both on the sunroof shade as well as the roofline. In fact, the wet spots went all the way back to the rear compartment.
My sunroof was entirely shut, all windows were shut, and the sunroof shade was in the closed position.
Needless to say, I am troubled by this. I obviously had not noticed this problem before.
Has anyone had this problem?
As a side note, I have noticed a lot of wind noise from up above even when the roof is fully closed (but with sunshade open). I now keep the sunshade closed to remove the wind noise.
Design flaw?
Old Nov 22, 2007 | 07:57 AM
Veight's Avatar
Design flaw?
You don't give any info on your car below your post so its tough to tell but...If its under warrenty take it to the dealer and ask them to redo your headliner.
Old Nov 22, 2007 | 08:11 AM
Mine is a 2004 530i. First year of the model redesign.
75K miles, but I did purchase the extended warranty to 100K miles.
Old Nov 22, 2007 | 01:48 PM
westcoast550's Avatar
This is not a new problem for the e60 , your car needs to have new seals installed... Good Luck.
Old Nov 23, 2007 | 08:16 AM
thanks for the info westcoast. Are you referring to seals around the sunroof panel?
I just checked my extended warranty and it looks like seals and water leaks are NOT covered. Which is disappointing. Do you happen to know how much $$ might be involved here?
Was this an early model year issue or do the newer E60s have this as well?
thanks,
Old Nov 23, 2007 | 08:18 AM
DRANGED's Avatar
+1 My 06 550i had the wind noise issue, no water leak though. I am not sure of price, mine was fixed under warranty. Good Luck
Old Nov 23, 2007 | 04:42 PM
pinguhk's Avatar
My Ride: Mini Cooper
take it back to the dealer to check it out, this is the 1st for a sunroof than I see on this forum
Old Nov 24, 2007 | 03:01 AM
chriscpm's Avatar
+1 here
Now I know what to suggest to the dealer.
LandRange
Oct 5, 2015 08:47 AM
abrookey
E60 M5 Discussion
Sep 22, 2015 05:05 PM
subieworx
Sep 21, 2015 01:19 PM
cbdoya
Sep 15, 2015 06:09 AM
LandRange
Sep 6, 2015 10:39 AM
