Sunroof Having Problems Closing. Ugh.
@vkhong, thanks for that link. i was about to perform the adjustment but my sunroof magically started to close fine again.
i looked a bit closer and noticed that the area behind and underneath the slipstream (draft) deflector was dry and slightly dirty. i also noticed there was some give in the springs area where the deflector mounts in at. i think this give was maybe causing the problem. so i cleaned the area on top and underneath the deflector and lubed the springs with white lithium grease. seems to be so far so good.
My Ride: 2008 BMW M5
i had the same problem, the issue was the headliner got pushed too far back. I didnt notice this until I went to close the sunroof and it retracted automatically. when the headliner is pushed back you should still see the handle 2-1/2" of it, well I mistakenly pushed it back all the way and could only see a 1/2". after I pried it out the sunroof closed properly.
maybe this was the case for you?
not sure a little dirt would cause the sunroof to completely retract?!
naw it wasn't the headliner. the handle was still very visible.
i really do not think it was the dirt either. i just cleaned it off because it was there.
i more so feel it was the deflector needing lube. when the sunroof retracted, i could see it come in contact with the deflector as the deflector wasn't moving out of the way about a mil.
i believe after i lubed it, the deflector was able to pivot out of the way more. like i said, i could see a slight amount of play where the deflector mounts near its springs.
My Ride: 04 545i
6spd m/t
Sport, Cold Weather, Logic 7
I'm currently experiencing this issue with my sunroof. I'll try cleaning and lubing the deflector and possibly re initializing it. My date was heckling me about it Tuesday, ungrateful youngsters ;p
Nothing like playing "Chicken" with your sunroof!
![Cool](https://5series.net/forums/images/smilies/cool.gif)
I had the same thing happen a while ago. Would try to close the sunroof and it would go down and pop back up and open. Didn't know what was going on. I figured though that since I hadn't opened it up in almost half a year, it might've dried the rubber seals and caused them to stick to the sunroof glass, I don't know, but after repeatedly trying to close and open the sunroof it eventually went down. I now open and close it a few times a week and it hasn't gotten stuck since. Just keep trying to open and close it multiple times and maybe that helps? Not sure
My Ride: 04 545i
6spd m/t
I'd been using mine continuously, but my car had the roof repainted last week and the shop may have removed the seals to do so. Turns out I reinitialized it and it works fine.
wow i can't believe my topic sprung back to life again.
just to update everyone, my sunroof deflector is still closing fine ever since i lubed it. yeah!
![Dance](https://5series.net/forums/images/smilies/imported/dance.gif)
