Sudden Oil Leak - Help
My Ride: 530i
Hi everyone, it's been a while but I'm back seeking everyone's knowledge and expertise. I just moved to Oklahoma
to start my career
and coming from Florida, it's very cold here.
Anyways, I drove shortly this morning and it was 25 degrees outside, possibly the coldest my car has ever endured. After a bit, I noticed a light burning smell and my iDrive notified me that my oil level was at a "minimum." I quickly drove home, added a quart of oil, and noticed fresh drops of oil on top of the air box (N52 engine), as well as on the underside of the hood directly above the air box. Any ideas?
I suspect it may be the oil filter housing gasket, since that's right next to the mess. But I don't know what the usual signs are for that. Other things to note: I didn't notice any other oil leakage on the engine, but I'm at 135k miles and just drove from FL to VA to OK (no problem at all) and even throw snow/sand/salt... my engine bay is very dirty. Also, I replaced the valve cover gasket and valvetronic gasket last winter. The nearest BMW shop/dealer is about 2-3 hours away and I don't even know if they're reputable or not. Any help would be awesome! Thanks.
![Hmm](https://5series.net/forums/images/smilies/imported/hmm.png)
My Ride: 2007 E60 530I
Check your oil filter cap and make sure the O-Ring is installed properly. If the oil is not coming from the oil cap O-Ring then check the Oil Cooler gasket to make sure this is not leaking. The gasket breaks down over time from extreme tempeture changes. If it isnt the oil cooler gasket it is where your oil filter housing assembly fits to your engine block. There is a gasket there that also will break down over time. The oil you are seeing on your airbox and underside of the hood is being slung there by your belts. The oil is dripping onto the belts from the oil filter assembly.
My Ride: 530i
My Ride: 2008 BMW 535i
Don't mean to restate the obvious, but I think once you start taking things off and following sludge trails, you'll notice that it's perhaps not so sudden. It's a super easy task if you should decide maybe you want to do it--there are just certain things to keep in mind when replacing it. I.e. don't remove the top radiator hose from the oil cooler because the gasket will expand.. you can't buy that gasket and will end up buying a new hose. Clean it really well before replacing and voila. Not difficult.. especially considering driving 2-3 hours away and then spending MORE money there. Just my 2.
