Stripped Guide Pin
Stripped Guide Pin
Hey everyone,
I was changing my brakes today and one of the caliper guide pins was stripped! Ruined my whole day...
I ordered a new pin as well as bolt extraction set but I was wondering if anyone here has any other methods or tips?
Here's a picture or the sucker:
Thanks for any help!
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Use the next size up from the right size. Beat it in and turn it, it should come out.
What tool did you use? Do not use allen wrenches on them. Only use torx bits. If you don't have a set get one it will save you from a headache in the long run
Sounds like a good suggestion though!
Model Year: 05 530i
Engine: 3.0 M54
Yea I have a good set then a set I use for instances like the one you have. It's best to put an extension on the bit then beat it in.
