Strange behaviour on 520d
My Ride: e60 520d 2006 model
Hello everybody. I've spoken many times through this forum about my problems with the automatic transmission(zf 6hp19). Just a month ago i replaced my tired tranny with a used one. very smooth in the beginning. i decided to do an oil change to give a bit more life in it. After that tranny behaviour got worse. Has anybody experienced the car shaking after a gentle accelaration somewhere between 1500 to 2500rpm? it's like something is clogged in the ecxaust.. you feel it like a strong earthquake from underneath. It is very annoying and i believe it is the main reason for creating damage on my tranny. (none obd errors)
i'm a lot ware of the life of the particulate filter that's why i did the exact procedure ( driving on the high way for 25 minutes with 60km on thy clock after 180000km done). No errors after that. Even the color of the filter was not so dark to be clogged. Do you suspect anything else? Really wierd. Can't stop it.
th3h1ghlander
10-09-2015 07:40 AM
