Sticker Decal
My Ride: 2005 525i: Mystic Blue, Auburn Dakota leather Premium and Winter Package, Xenons
Extremely mad...I had a sticker decal for a parking permit...and it was located in the driverside rear window...and was hard to take off since I found out it was located in the wrong place...although the stupid decal has left behind a horrible stickey substance....and i tried waxing it off no luck..i need help loooks so ugly.
Guest
Posts: n/a
...[snapback]103898[/snapback]
My Ride: 05 525i SilverGray/Black Step/Nav/Cold/Premium/Xenons
If its on the outside just use a glass cleaner & a razor blade, soak it first with the cleaner then lightly scrape off the glue. If its in the inside use an adhesive remover, spray remover on a small towell & rub in it will start to break up keep rubbing then follow up with a window cleaner. PS if its in the inside rear glass DO NOT USE a razor as you can cut your rear deforster lines if your not carefull.
ucsbwsr
Sep 19, 2015 10:58 AM
jimmychef
Jul 7, 2015 05:17 PM
