steering will tilt not working
My Ride: 2006 bmw 530xi
My Ride: 2008 528i
I?ve had problems with the steering wheel before. The first time, the steering wheel wouldn?t go back up after turning the car off. I had the column replaced then it worked fine. Now the steering wheel won?t go down but it only happens intermittently. Of course, the SA can?t reproduce the problem. He did say that this model has been having problems like this and replacing the entire column is not uncommon. Wish I could be more help.
My Ride: 2004 Black Bmw 525i
WELL I KNOW FOR SURE IM NOT GONNA REPLACE MY COLUMN BUT IM TRYING TO SEE IF MAYBE THE SWITCH WENT BAD OR IS THERE JUST HAS TO BE A RESET PROCEDURE .... I COULD JUMP THE MOTOR ON FOR THE COULMN SO I HAVE IT SET TO WHERE ID LIKE BUT ID LIKE TO HAVE IT WORK WHEN I COME AND GO OUT OF MY CAR....
My Ride: carbonized MB coupe
i had this problem with my old car, when you switched off the column didn't go up.
my fix was this:
switch on the car
move the steering wheel down (with the switch) and then move it to the top and down again.
Switch off car, get out and lock and re-enter the car.
Switch on and see if it works
my fix was this:
switch on the car
![](https://5series.net/forums/public/style_emoticons/default/twoup.gif)
my fix was this:
switch on the car
my fix was this:
switch on the car
