Steering wheel offset
Old Sep 16, 2009 | 02:16 PM
jgbmw's Avatar
I just had an alignment performed; the alignment is fine. However, the steering WHEEL is offset slightly to the left. Is there such a fix as Active Steering reset procedure for this issue? The dealer saids that another alignment will not fix the issue.
Old Sep 20, 2009 | 09:08 PM
ivan545's Avatar
I had that issue, i had my alignment done three times to have that corrected, i have active steering the dealer charged $240 for the alignment why not make them do it right thats what i did, and the problem was finally corrected and i asked for a printout also be demanding, its not suppose to be like this.
Old Sep 21, 2009 | 05:49 AM
Anzafin's Avatar
My Ride: Bmw 530d 2004
Do you have Active Steering? I don't, but I thought that this kind of problem could be corrected via reset procedure from the idrive or something .
Old Sep 22, 2009 | 06:22 AM
Schu Dog Nite's Avatar
My Ride: 2004 545i sport, 46k, titanium grey with dakota grey interior, auto stick, all options except HUD
I was told you can reset the steering by turning the wheel all the way to the left, all the way to the right then all back to the left. This I guess applys to the fly bye wire steering, but dont qoute me, I was told this.
Old Sep 22, 2009 | 06:26 AM
ktlocklear's Avatar
My Ride: '06 550i '84 Nissan S12 Turbo
I've read something similar to that on here somewhere
Old Sep 22, 2009 | 06:28 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
I assume you don't have active steering...
If you don't, and the steering wheel isn't centered after an alignment, then I'm guessing the people who did the alignment are clueless. If you do have AS, then there are two different reset procedures. One is sort of automatic where the car will adjust itself over time (or you can do the turn the wheel to the right and to the left as described in other threads) and the other is a reset procedure that takes only a few minutes but the car has to be connected to a BMW service computer for it to happen.
Old Sep 22, 2009 | 07:33 AM
DrLev99's Avatar
Ooooh...that would irritate me!
jfmartin25
Nov 2, 2022 01:42 AM
Kasmo
May 7, 2019 03:30 AM
Alan111
Nov 9, 2015 09:01 PM
coolspot
May 24, 2015 12:22 PM
TexaZ3
May 6, 2015 09:54 AM
