Steering wheel 'creaking'
Old Mar 6, 2006 | 02:22 AM
idoru's Avatar
My Ride: 525d Sport Touring, Carbon Black, Dakota Black Leather, Maple Wood interior trim "How much more black could this be? And the answer is ‘None. None...more black’ " - David St Hubbins, Spinal Tap
Anyone experienced this? Not the same as the 'clunking', due to a joint that needs to be lubricated where the steering column meets the steering rack - had that problem, and it has been fixed. This is more like a rubbing sound coming very distinctly from the steering wheel... with luck it will be just a simple lube job, rather than some sort of problem with the standard (not Active) power steering .
Old Mar 6, 2006 | 02:52 AM
BMWJIMT's Avatar
My Ride: 525, Dec 2003, Silver Grey, Black Dakota Leather, Bluetooth, Satnav, 18'' Runflats, Sunroof, Folding mirrors, Automatic
Mine had it last year, dealer lubricated something in steering column & it was OK for a while. But the problem came back, rubbing sounds like it is from just befind steering wheel. Dealer had a look & are changing entire steering column tomorrow.
Old Mar 6, 2006 | 05:12 AM
subterFUSE's Avatar
My steering wheel has this faint, but noticable, clicking sound when I turn it. I think it might have something to do with the Active Steering. i've never asked about it, though.... because I usually don't hear it with the music on.
Old Mar 6, 2006 | 08:01 AM
idoru's Avatar
That is it, in a nutshell. Out of interest, did you get an explanation as to why the whole steering column is being replaced?
Old Mar 6, 2006 | 10:39 AM
BMWJIMT's Avatar
Dealer said that the problem was due to some kind of nylon bush rubbing in steering mechanism. I stressed that I did not want it ' lubricated ' again, but fixed properly ( as where in the service schedule does it say oil the steering column bushes every 6 months !!, its not as if you can do it yourself ).
Old Mar 7, 2006 | 11:35 AM
idoru's Avatar
Thanks, I'll bear that in mind when I take it up with the $tealer.
jfmartin25
Nov 2, 2022 01:42 AM
Kasmo
May 7, 2019 03:30 AM
Alan111
Nov 9, 2015 09:01 PM
coolspot
May 24, 2015 12:22 PM
TexaZ3
May 6, 2015 09:54 AM
