steering wheel controls removal 08 528i
My Ride: 08 528i
Is there any way of removing or replacing the steering wheel control without taking the steering wheel apart? I want to replace the plastic piece around the buttons as the plastic has started delaminating.
My Ride: 2008 550i w/M-Tech, Sport and Cold Weather Pkg
You will need to remove the airbag regardless. Little hole underneath that you need to stick an allen driver up (could use a screw driver, but you are trying to push a bar upwards that releases the corners of the airbag). It took me 30 minutes with a phillips screwdriver as the tip would not stay on the bar due to its shape. Thats why a flat headed allen screw driver is ideal. A standard screw driver could work as well but you would need to make sure the head is positioned across the bar, not parallel to it.
