Steering wheel compability?
Old Aug 27, 2008 | 05:10 AM
NPe's Avatar
NPe
My Ride: M6 E63 Sapphire black Z3 Coupe R4Turbo Hellrot, semi race. (670bhp) Z3 Coupe V8Turbo design work ongoing, full race. Sold: 545i Titanium Silver
Is anything changed on the steering wheel interface to collumn before and after 09/2005?
Is it possible to use a 2006 steering wheel (#1 in realoem) on a 07/2004 build car?
Airbag and everything else is left untouched from the old steering wheel.
http://www.realoem.com/bmw/showparts.do?mo...hg=32&fg=35
Reason for the change is to get a new leather grip. The old one is shiny and worn.
Old Aug 27, 2008 | 06:10 AM
BlaSTiWi's Avatar
Yes some kind of notch or something similar like that on the back of the steering wheel hub has changed.
Due to that you'll not going to be able to fit '06 steering wheel into your '04 directly.
Old Aug 27, 2008 | 06:53 AM
NPe's Avatar
NPe
Allright, but with a slight modification by drilling a hole or similar will solve the issue then I guess!?
Old Aug 27, 2008 | 06:59 AM
BlaSTiWi's Avatar
It could be, I couldn't remember which year has hole & which year has the metal notch, if you search you'll find a member that did modified the steering wheel but not sure same case as you or the other way around older steering wheel to newer car.
Old Aug 27, 2008 | 07:32 AM
AlexFW's Avatar
Model Year: 2005
Old Aug 27, 2008 | 08:35 AM
NPe's Avatar
NPe
Thanks AlexFW!!
If I modify the new steering wheel, to fit collumn, do I f..k up anything?
Or is it just to grind away
Old Aug 27, 2008 | 09:42 AM
Ricracing's Avatar
The E60 did get a mayor safety "facelift" from somewhere in the 11/04 production!
From only 3 EuroNCAP stars to 4.
Note that not all '05 models have it.
Also the doors and the dashboard where modified and some new programming was made to the airbags.
(Seems that the steering wheel hardware was also updated).
The LCI is now a 5 star car says BMW Nordic!
Old Aug 30, 2008 | 12:29 PM
NPe's Avatar
NPe
It?s nice to have a neat tool shop in the garage
Steering wheel is in place.
The operation is not a recomended DIY, get the correct steering wheel if you can!
Both front and rear side of the steering wheel needs excessive modifications. Material build up etc.
jfmartin25
Nov 2, 2022 01:42 AM
Kasmo
May 7, 2019 03:30 AM
Alan111
Nov 9, 2015 09:01 PM
coolspot
May 24, 2015 12:22 PM
TexaZ3
May 6, 2015 09:54 AM
