Steering wheel angle sensor
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
I have an 05 530i that is only driven for about 2500mi a year. I have a steering wheel fault and have been trying to clear it (by cleaning and reinitializing). Other than replacing the part can this be an alignment issue. It has been almost 8 years since I have had one done
Model Year: 05 530i
Engine: 3.0 M54
No I have the older version so it's analog. I have taken it out and cleaned it and still getting the intermittent error. I'm thinking if it was bad I would always have the light on unless it's just on the way out. I had it replaced in 2012.
Do you have active front steering?
In the event you do, here's a BMW overview/training document.
https://www.bimmerfest.com/forums/at...2&d=1526135469
Rather than re-type and re-do pictures here, this is what I did on my E53: https://xoutpost.com/bmw-sav-forums/...r-fix-0-a.html
Model Year: 05 530i
Engine: 3.0 M54
Wow yours was pretty damaged. When I took mine apart it looked fairly good. It was just real dirty. The one thing I didnt do was take the disc off. I will do that and clean everything up with some Hosa D5S-6 and report back
