Steering Wheel
My Ride: [i][b][u]Since 19 august 2004[/u][/b][/i]: [color=red][b]530i[/b] High Executive[/color], Silvergray with beige interior, Popular wood, Servotronic, Sportssuspension, electric foldable and dimmed mirrors, dimmed interior mirror, pappelmaser braun wood, cupholders, styling 123 18" wheels, Logic 7, Steptronic, alarm class 3, electric sunscreen in the rear and suncreens for sidewindows, Comfort seats, heated seats, Xenon with headlightwashers, Adaptive corner lights ALC, Advanced airconditioning, lightpackage, Nav Pro, 6 cd changer, side airbags rearseats, bluetooth siemens S55, chrome kidneys, gearlever with wood, voice recognition retrofit, front windshield with green band.
Waiting for trunkopener button from Hobi :)
Originally Posted by Iceman' date='Sep 27 2004, 04:29 PM
How tall are you Dennis?
[snapback]38710[/snapback]
But I feel bigger hahaahaha
The steering column can be calibrated just like the windows (going all way up and down procedure).
In my experience it will only work correctly with software 13.1 (stops at EXACTLY the same position all the time)
My Ride: 2002 545i sport pckg,sirius,active steering,grey on black
I had the same thing happen about 2 mos ago. The steering wheel went up
to a certain level but hampered exiting the vehicle. I pressed up on the lever
that raises the wheel and at the same time gently pressed up on the wheel
itself. It raised approx. 1.5 to 2 in. more. Since then it raises all the way by
itself. Go figure.
itself. Go figure.
My Ride: E90 M3
Model Year: 2011
Played with the steering wheel upon leaving the office and I do have it all the way up. The real variable in terms of seeing the guages is the amount you recline your seat. I keep my seat very straight, almost no recline, so I need the steering wheel all the way up to have an unobstructed view. If I recline the seat even a little bit, I can lower the wheel and still see the gauges fine.
Originally Posted by my530i' date='Sep 27 2004, 06:09 PM
The only problem I have with the steering wheel is that it obstructs the right signal and #4 on the tach. This is the most confortable position that I can adjust.
[snapback]38747[/snapback]
I'm excited about the possibility of raising the steering wheel a bit higher than it has been able to go with the motor going up to the top. I'm 6'2" and cannot see the right arrow usually.
I do remember though, the most cars have the steering wheel angled slightly off center, that is angled slightly to the left/dirver's door because of the location that it connects under hood into steering components. I'm going to check on the steering wheel angle as seen from above to know if it also is slightly angled like many cars are.
