Hi, This morning been in a supermarket car-park and when I tried to reverse my 525BMW E60, with the steering turned to the limit, it went stiff and hard to turn, then got a CHARGING FAULT. Switched off and restarted and steering turned normal, then did it several times when turning sharp turns.
Managed to drive home slowly with steering working but it turned stiff again when parking. I have noticed that; Steering pump seizes or becomes stiff at extremes with the Alternator not running (charging Fault)SMELL OF BURNING BELT Does not happen all the time. When this happens, If I stop and restart engine steering will turn normal but if left in this position will become stiff again. Oil is not Low. Changed steering fluid about a year ago as I fitted a new engine :hyper: . Any ideas? Could it be overshooting a setting and locking up? Will DIS diagnostics show anything? Seems to be activated when the steering goes to the limit |
my guess is you have a weak belt tensioner, and the belt stops moving(slips on pullies) when the power steering pump is under load.
If steering fluid is at normal level, it could be a known issue of faulty steering pumps. Let it check if you are under warranty.
Originally Posted by flowmaster
(Post 1364986)
ALL of you are DEAD WRONG guys!
sorry for the delay in posting as I was a bit hosp and could`t drive.. Yesterday I looked carefully and the pulley on the crankshaft is stopping. There is a Rubber moulded pulley fitted on the crankshaft pulley and it has broken down so it is slipping......... Thanks for your suggestions just the same. |
Originally Posted by sputnik
(Post 1371967)
sorry for the delay in posting as I was a bit hosp and could`t drive.. Yesterday I looked carefully and the pulley on the crankshaft is stopping. There is a Rubber moulded pulley fitted on the crankshaft pulley and it has broken down so it is slipping......... Thanks for your suggestions just the same. All of the members' suggestions were guesses based on the description given. The only way to find the root cause is to open the hood and checking the car. Crankshaft pulley (aka Harmonic Balancer, vibration damper, etc) is essentially two metal pulleys with rubber part sandwiched in between to absorb the vibrations. It deteriorates over time. I check the condition of the harmonic balancer (crankshaft pulley) every time I open the hood on all my cars as a general practice. |
:) :) Hi- DID NOT WANT TO SOUND OFFENSIVE MATES.
I never ever suspected the cause to be coming off this myself but I was pointing this out. Hope nobody goes through this as the bill can go up to around 500euro :bash: |
(Post 1371967)
sorry for the delay in posting as I was a bit hosp and could`t drive.. Yesterday I looked carefully and the pulley on the crankshaft is stopping. There is a Rubber moulded pulley fitted on the crankshaft pulley and it has broken down so it is slipping......... Thanks for your suggestions just the same. :) |
