Steering Malfunction
My Ride: 2005 545i
Sport Package/ Step/Orient Blue/ Anthracite Interior/ Navigation/ Cold Weather Package/ Logic 7/Sirius/ Fold down Rear Seats/ Power Rear Shades/ Xenon Adaptive Headlights/ 6000k Fog lights/ LED Angel Eyes/ LED interior/Smoked LED Side Signals/ Shadow Grill/ Shadow line Trim/ Shadow Matte Black Badges
Hi to all!
The steering malfunction was intermittently coming on depending on the weather outside
. When I turn on the engine the malfunction will come on right away, but when the car was fully warmed up, the malfunction will be gone when you turned off the engine and start it again. On another note when it is warm outside the malfunction will not appear at all. Thank you!
Hi to all!
My Ride: 2005 545i
Thank you all for the reply!
Turn on the car. Rotate the steering wheel all the way to the left. Then rotate it all the way to the right. Turn it back to the normal position and turn the car off. This should fix the problem. This happens to me when the car is parked for a few days without being driven (usually on an uneven surface.)
My Ride: 2015 535D M Sport
This message was the first indication that my alternator / voltage regulator was failing in my 2005 545 with around 68000 miles on it. If you continue to get this message I would seriously consider the alternator as the cause. It's a common problem, search to find more details.
Vman33
03-14-2022 04:43 AM
Johnnywadd
09-03-2015 01:23 PM
