Steering clunk
#21
My Ride: BMW 550i
I had a similar clunking noise, it was specially noticeable when trying to parallel park, this was the fix
https://5series.net/forums/e60-discu...3/#post1372719
About a year later, I noticed a different clunk specially when leaving from a parked position, it turned out to be the bolts for the front struts - the ones inside the engine bay. Tightened them up, clunking went away.
most likely and it is common on e60 you can't tell until you replace it even when you take it off it looks ok but when new one in place noise will go off. I would start from this part STEERING KNUCKLE COUPLING
Vman33
03-14-2022 04:43 AM
Johnnywadd
09-03-2015 01:23 PM
