Steamed up headlights.
Old 03-29-2011 | 09:48 AM
  #31
Shlooky's Avatar
My Ride: 545i
Originally Posted by rhinosaur
That is exactly what they did with my car this week. They oven-dried the headlights to remove the moisture and then replaced the gaskets that should prevent humidity from getting inside.
I'll wait and see how it evolves when it rains again.
Can the outer glass be removed? Or do I have to remove the entire headlight assembly? I have the same issue on my 545i but the glass itself is dirty and would like to clean it out if possible.
On my E39 it was easy, but it had no active headlights or XENON for that matter, now my E60 however is a different story.
Thanks
Old 03-29-2011 | 09:59 AM
  #32
DavidF's Avatar
My Ride: 545i sport
No, the lenses cannot be removed without damage (glued to the housing). The entire headlight assembly can be removed by releasing four screws/bolts and two electrical connectors. Then, wiggle it out. To make it easier, also remove the upper bulb access cover.
When polishing my headlight lenses, I inadvertantly introduced moisture into the assembly which caused them to fog over. I removed the headlight assemblies again, oven dried them and the foggin has not returned.
Old 03-30-2011 | 08:02 PM
  #33
turboawd's Avatar
My Ride: 2006 BMW 550i
could just pop off the rear cover on the headlight and blow a hair dryer in there for a bit, and on the front to heat it up a tad.
Old 03-30-2011 | 09:16 PM
  #34
v_therussian's Avatar
I remove the cap and just let it sit like that for a few hours, when I don't have to drive anywhere. Clears it right up. I've come to live with it and treat it like a little "quirk". Just don't forget to put the cap back on, or the heat from the engine compartment might make it worse
Old 04-01-2011 | 04:06 AM
  #35
limbows's Avatar
My Ride: E46 E60
+1 v_therussian
Just open the cap and let it overnight, it will clear eventually.
I think It's due to bad air circulation inside the headlight.
I also didn't over tight the cap... Result is no more condensation..
Old 04-01-2011 | 07:30 AM
  #36
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Yea, from what I know, it's actually "ok" to take off the inner cap. By design, water/rain shouldn't get into there, but don't take this as a guarantee.
ripley
DIY: Do It Yourself
09-19-2015 06:21 PM
hmilycar
E39 Discussion
08-25-2015 10:44 PM
umnitza
08-20-2015 04:34 PM
turbo_mustang12
08-03-2015 09:53 PM
Quick Reply: Steamed up headlights.
