standard audi woes....
Old 11-16-2004 | 01:34 PM
heezy545i's Avatar
Originally Posted by 04r1belgium' date='Nov 16 2004, 02:49 AM
Hmmm.... probably took out the standard cd player, taped it over with aluminum foil, laid down fiberglass & resin, let it dry, take off the now hard fiberglass mold, apply more glass to the inside, cut DIN hole, dremel the sides till they are smooth, try for fit, sand a lot, apply bondo, sand, sand some more, paint, done.
Probably fiberglass DIY project.? I will be fiberglassing a sub box and an amp rack (or at least attempt to) for starters...? Maybe I'll try the facia later....
[snapback]56719[/snapback]
Yea, but I think the bigger problem is working with Idrive and the fiber optik network in the car.
Old 11-17-2004 | 05:40 AM
skaffa's Avatar
My Ride: -04 530D
What I have asked about audio upgrade, the answer has always been: "Forget that and build it up with totally new parts, but You also have to have old system in place, otherwise iDrive stop working."
So wonderfull is todays world of hi end cars!
Skaffa
ENDEE666
06-07-2016 10:31 PM
JonathonK
08-25-2015 03:30 PM
umnitza
08-20-2015 04:34 PM
Germaniks
08-09-2015 10:50 AM
PelicanParts.com
07-24-2015 01:26 PM
Quick Reply: standard audi woes....
