staggered wheels for xi?
My Ride: 2009 Ford F-250 Harley Davidson Edition
6.4L OHV Power Stroke Turbo Diesel V8 (350hp/650lbft)
Blue Flame Package
Dual Alternators
Touch Screen Navigation + DVD Player
Uplifter Switches
Trailer Brake Controller
Traction Control
Rapid Heat Supplemental Cab Heater
Rear View Camera
Power Slide Moonroof
im planning on buying some new wheels within the next 2 weeks but was told by a few ppl that staggered wheels on the xi model isn't a good idea because of the limited slip differential or some bs. can anyone elaborate?
You can get 18" 124's (245/275mm tyres) but front/rear offset is 43/55 - which is quite different to the normal models (20/32)...
You can totally do it. I've been doing it for some time now and it's great. Hell, I even have spacers on my car too (10mm rear and 5mm Front). That's a myth about it screwing up the AWD system.
Here's why it's BS... The X5 4.8i with 21" wheels is a staggered set-up, direct from BMW. If it was an issue with the x-drive system, do you think BMW would be doing it on their trucks, let alone their sedans?![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
You're fine. I've done it, DrLev99 has done it, KU530 has done, 06xi has done it and so has Bambi. And, if you look at realoem.com, they make a set of 124's just for the xi model that is a staggered set-up. The fronts are ET43 and the rears are ET55, for a staggered set-up.
My Ride: 2005 530i, Premium/Sport Packages. Heated Seats, Sat Radio, Mystic Blue Metallic and Dakota Gray Leather interior. Active steering and headlights, M5 166 wheels
Hey wow you are on 166? Do you have a full pics of your car, pls? I'd like to see how it looks...
Originally Posted by StealthM8' post='553690' date='Mar 31 2008, 01:57 PM
To me the thing to watch for is that the front and rear tires are the same outside diameter to keep the AWD system happy. ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
Have you seen SP530xi's car? He was the first to put the 166's on an xi. Take a look at the front to rear shots. You can clearly see they stick out beyond the wells. The owner now knows this and hates it.
http://forums.e60.net/index.php?autocom=ga...si&img=3405
That's what I thought
and made me wonder...
Originally Posted by C's Bimmer' post='553794' date='Mar 31 2008, 04:49 PM
It can't look that good if they are OEM 166's. His wheels must be sticking out beyond the wheel wells, due to the offset.
My Ride: 2008 535xi -- took delivery January 24th, 2008 -- Space Gray w/black dakota leather interior and Bamboo Anthracite wood trim, Sport Package / Premium Package / Cold Weather Package / Logic7 / Bluetooth / IPOD / NAV / 18" Star Spoke 124s...BUT I could not resist the M Aero Kit, tinting the windows and adding front/rear blacked-out Roundels
too solid - C's correct...here is a pic of the 124s
