Stabilizer Bar...fluid sweat??
My Ride: 2005 545
Clean it up and see if its leaking from the boot or from the fitting . Mine was leaking and alls i did was tighten the fittings some, and the leak stopped so far it hasnt leaked again .
My Ride: 545i sport
Mine is "wet" all the time as well. Does not leak enough to bother fixing. Tightening the line fittings did not solve the problem. I think this issue is fairly common.
Also keep an eye on your PS fluid level as the sway bar shares fluid with the steering rack (use only CHF11S if the cap is so marked).
Mine also "sweats" and I have searched for shops that will overhaul them like a steering rack but have yet to find one. I think ZF has a factory overhaul facility in Illinois, but as far as I know only deals through BMW dealers.
rice_rocket88
08-27-2015 12:10 PM
PelicanParts.com
08-14-2015 10:15 AM
