squealing brakes
My Ride: 2011 550i M sport
hello all. I have a question regarding my 2005 545i with smg. Recently, after the waether got cooler, i noticed a slight squeal from the brakes. It only happens when I first start the car and reverse out of the garage or parking spot. No noise when coming to a stop while driving. The I-drive states I have 13,000 miles left before the fron brakes need service. Is this due to temp change and temporary or is it indicative of needing new brakes (again, no noise when stopping after driving)?
Thanks
Thanks
I suppose that's pretty normal.
My brakes squeak a bit also at very low speeds (about 1-2 mph) with less than 3,000 miles on the car.
My dealer told me that the squeaking sound is caused by the chemicals that the car wash shops use to clean the rims and tires. I could have prevented the noise by washing the rims and tires with soap and water instead of chemicals. They will replace the pads once, but if the noise comes back then "I'm on my own" unless I want to pay to replace the pads.
I've gotten used to the noise now. Since it also happens to me at low speeds, as long as my windows are rolled up, I'd just pretend I don't see the neighboring drivers looking my way to find the source of the squeaking sound!![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
Interesting. I will start washing it on my own. Do you know if the noise stops after a certain amount of time or is it permanent even if I never use the carwash again?
My Ride: Mini Cooper
Loads of dust and sound.
let them run in for other few 100 miles or try taking the pads out and chamfer the edgers out.
I change my to EBC green stuff and no sound and dust, now I don't have take so long to clean my wheels.
My Ride: 2007 BMW 550, Sport, Navi, PS, CWP, Sirius
bestofthebest
03-28-2016 02:47 PM
