Squeaky Rear Left windows
Old Jun 22, 2005 | 03:28 AM
bdav's Avatar
Hi all...
Recently i've noticed a squeaking on the afformentioned window. It only does it in the fully up position... if i drop it as little as 1/2 mm, it stops - so im guessing its the top seal.
Has anyone else had this problem? Is there a quick fix, or is it back to the dealer? Will they know about it?
Thanks in advance
Old Jun 22, 2005 | 03:43 AM
Peter530i's Avatar
This is very well and almost every car's problem. Search the forum and you will find a lots of info. IT is the door top sealing, either put some greas on it or go and have it exchange under warranty. Again, very well known problem to everybody here
Old Jun 22, 2005 | 05:29 AM
bdav's Avatar
Is it the door top squealing even if its only when the windows up???
Old Jun 22, 2005 | 07:06 AM
bigjohndaly's Avatar
Take it to the dealer. Most likely the gasket and seal need replacing.
skrelnik
Mar 25, 2015 10:50 AM
fmusbmw
Apr 11, 2004 04:13 PM
Beemer
Jul 9, 2003 05:38 PM
Jun 17, 2003 09:38 PM
