squeaky front break sound!!
Good evening gentlemen.
First off, I understand that there are many posts already regarding this problem.
i already have spent good few hours to find the answer what exactly i need but no luck...![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
I have a 06 525i in canada with still warranty on but i'm not sure if i also have the maint. plan or not. If the maint. plan was something that i needed to purchase separately, then it's likely that i don't have one.
I've had this problem since i hit around 40,000km and now i'm running around less than 60,000kms.
this is just too annoying to hear that break squeaky sound while i have to drive around the downtown every single day with lots of people and lots of buildings.
i took it to the service department and they said that i got the "faulty break sensor."
and it cannot be fixed unless i purchase a new pad and it is not under warranty because it's over 20k kms or something.
when i tried to look up in this forum for the PUMA rules and the service bulletin, some of them sounded like the break sensor fault should be covered by warranty and some sounds like it needs to be fixed at my own cost!![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
What is the truth?
and Does anyone know which thread that has the official PUMA and service bulletin for the break squeaking?
Can anyone think that I can get those break replaced by warranty while i'm running 56,000kms?
Any inputs will be very helpful for me.
Thank you very much in advance.
What is the truth?
This is only one i could found and i read some posts that there is more recent one.
Regarding the one i have below, there is no restriction of milege as it is due to geometric problem of break sensor.
but why is my dealership saying that there are restrictions?
"In case of a customer complaint, install improved brake pad wear sensor. Improved wear sensor geometry and material have been implemented in 01/06."
My vehicle is 06 but was made in 05...so i guess they have to replace my break system?? no??
SI B34 02 06
Brakes March 2006
Technical Service
This Service Information bulletin supersedes Service Measure B34 202 03 dated July 2003.
SUBJECT
Brake Squeals
MODEL
E60 (5 Series)
E61 (5 Series Sports Wagon)
E63 (6 Series Coupe)
E64 (6 Series Convertible)
SITUATION
Some customers may complain of a brake squeal noise during light brake application.
CAUSE
Wear sensor geometry (part of the sensor head protrudes beyond the edge of the brake disc).
Wear sensor material (the material combination of the wear sensor/brake disc can cause squealing noises under certain circumstances).
CORRECTION
PROCEDURE
Determine that the noise is not caused by random occurrence which can happen just before the brake pad wear limit is reached.
Replace the brake pad wear sensor and new brake pads only on the noisy axle.
PARTS INFORMATION
Part Number
Description
Quantity
34 35 6 776 421
Wear Sensor, Front E60/E61/E63/E64
Wear Sensor, Rear E60/E63/E64
Wear Sensor, Rear E61
WARRANTY INFORMATION
For information only.
SI B34 02 06
Brakes March 2006
Technical Service
SUBJECT
Brake Squeals
MODEL
E60 (5 Series)
SITUATION
CAUSE
CORRECTION
PROCEDURE
PARTS INFORMATION
Part Number
Description
Quantity
34 35 6 776 421
I had SI B34 02 06 performed on my car at 37,000 miles while under warranty. Sensors and pads were replaced. Took care of the squeals, but messed up the brake system CBS ( condition based service) notifications, even though I was told it would not. As a result, I did not not get a brake service notification while under warranty and missed out on new rotors. I am still discussing the matter with the dealer and will likely get BMWNA involved.
My Ride: 535d M Sport
Individual Le Mans Blue
Individual Platinum Leather (Extended)
19" Mixed Alloys
Heads Up Display
Piano Black Inserts (might change to aluminium, kids leave fingerprints everywhere)
BMW I Pod Connection
Aux Input
Business Sat Nav
BMW Rear Entertainment System incorperated in the roof
Heated Seats
Bluetooth
Sun Prot Glass
I had rear o/s brake noise on my (07) 535d, it sounded like a bus stopping. Dealer replaced the rear pad sensor o/s.
But since having it done have noticed the noise coming back again.
Maybe they should have replaced the pad as well, typical warranty proceedure - only replace the faulty part but not the associated parts.
My Ride: 2013 535i (White with Oyster Interior. Premium Package, Navigation, Technology Pacakge, Park Distance Control, and Rear View Camera)
I also had SI B34 02 06 perfoemed on my car. It only last about 3 months, then the squeal noise came back.
My Ride: 2006 530i Sport
Silver Gray - Black Leather - Anthracite Maple
Manual Transmission
Premium Audio
Cold Weather Package
Rear sunshade
Sirius Radio
Autobahnd Roadblock (3M) film kit
My dealer replaced one set which didn't correct the issue.
On the subsequent visit, they replaced all of them and the problem has been 100% fixed ever since. That was in the June 07 timeframe.
i have the squeaking voice too. how do i know its the sensor or the pads?
anyway, how does the sensor look like?
and am i supposed to change the rottor along with the pads?
Originally Posted by bad2bone' post='542980' date='Mar 11 2008, 01:48 PM
so let me get this straight. is it break or brake?
i can take a break and then hit the brakes?
have a break, have a kitkat!
or slam on the brakes. what????
thanks. i tried to correct it but couldn't see the edit button.
and also thank you very much for the input gentlemen.
it was really helpful.
now i need to call the dealership and have another big argument about it.
don't understand why they wouldn't replace it under warranty while it was due to geometry problem that came with the car.
