Sqeeky clutch pedal
Anyone know what parts I need to stop this squeaky clutch pedal? My word it is worse than nails on a chalkboard! LOL!
My car is a 2006 530i with 6-speed. TIA!
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Have you identified that it's the actual pedal or assembly that is making the noise? I would get down there and isolate the problem and you will get closer to the answer. I had a noise from my pedal for years. Replaced it a couple months ago. It's not expensive if you do it yourself. The pedal cost less than $50, you have a pin and a spring. I think it's one of those or you're looking at the master cylinder or assembly being the issue. There is a bushing that's in the pedal but you have to identify where the noise is actually coming from before anyone can recommend the correct fix
N52E60 (03-15-2023)
