Sports package question
My Ride: 2008 BMW 535i
I can't seem to find the answer via my Google searches...
What exactly is included in the sports package? This would be for a 2008 E60, non M.
I've seen some listings that include the sports package and you get the SMG trans/"sports" button by the shift knob... then some don't have either.
ZSP Sport Package - $4,700
Sport alternate suspension; Roll stability control; Sports steering wheel; Rear alloy wheels with 18 inch rim diam and 9.0 inch rim width; Front other tires with 245 mm tire width, 35% tire profile and W tire rating, rear other tires with 275 mm tire width, 30% tire profile and W tire rating; Spacesaver steel rim internal spare wheel; Shadowline trim; Aerodynamic Package; Includes: [456] Multi Contour Seats
or you can go here to see what other listed options mean
http://www.automotive.com/2008/101/b...ges/index.html
Thanks for that... but thats pretty much what I've been finding as well.
Does SMG/sports mode have nothing to do with the sports pkg?
I'm looking for a 535i, not the 550i. Safe to assume the SMG comes standard on the 550i and is an option for the 535i?
My Ride: 535i
SMG wasn't available in 08, the button you are seeing is for the Sport Auto Trans (SAT) option. Basically it is just the paddles and a little tweak of the gear shifts/ throttle response. The transmission itself is the same and the performance times are the same.
My Ride: 535i
TexaZ3
05-06-2015 09:54 AM
S4CH
05-04-2015 09:37 AM
