sorry guys Passenger Restraint error - codes posted
My Ride: 525i
Passenger Restriant Error that won't let me have any rest! 2004 525i that looks and drives perfectly, so this is making me nuts. I have posted codes from Carly below. Does anyone have advice? I am thinking BST cable replacement, but I thought if it was bad the car would not start? No accidents or reason to think it's bad? Is there a fuse? Other? Thanks.
Airbag:
Advanced Crash and Safety Management (ACSM)
Passenger side of wrong measuring range
Code: 0093DB
Safety battery terminal
Code: 0093B2
Driver's knee airbag
Code: 0093B8
Satellite B passenger side pillar Y
Code: 0093E4
seat belt contact passenger side rear
Code: 0093BD
passenger airbag POS
Code: 0093BE
Satellite front left door / Tuer vorne links
Timeout ID 05H SBSL
Code: 009631
Timeout ID 0BH SASL
Code: 009637
too little telegrams
Code: 009642
Timeout ID 20H SSFA
Code: 00963C
Satellite front right door / Tuer vorne rechts
sorry, unknown fault
Code: 009B95
Timeout ID 05H SBSL
Code: 0096B1
Timeout ID 0BH SASL
Code: 0096B7
Code: 0096C2
Timeout ID 20H SSFA
Code: 0096BC
Satellite B-pillar left / B-Saeule links
ECU not present/no response from ECU
Satellite B-pillar right / B-Saeule rechts
Satellite center / Mitte
Timeout ID 0BH SASL
Code: 009AB7
Timeout ID 05H SBSL
Code: 009AB1
Code: 009AC2
Airbag B-pillar left/ B-Saeule links
Airbag B-pillar right/ B-Saeule rechts
Code: 0098B7
Code: 0098B1
Code: 0098C2
nse from ECU
Car Communication Computer CCC
Message failure
Code: 00E18F
Center-Konsole
MFS fault
Code: 009FEB
CU
Airbag:
Code: 0093DB
Code: 0093B2
Code: 0093B8
Code: 0093E4
Code: 0093BD
Code: 0093BE
Timeout ID 05H SBSL
Code: 009631
Timeout ID 0BH SASL
Code: 009637
Code: 009642
Timeout ID 20H SSFA
Code: 00963C
Code: 009B95
Timeout ID 05H SBSL
Code: 0096B1
Timeout ID 0BH SASL
Code: 0096B7
Code: 0096C2
Timeout ID 20H SSFA
Code: 0096BC
Timeout ID 0BH SASL
Code: 009AB7
Timeout ID 05H SBSL
Code: 009AB1
Code: 009AC2
Code: 0098B7
Code: 0098B1
Code: 0098C2
nse from ECU
Message failure
Code: 00E18F
Center-Konsole
MFS fault
Code: 009FEB
CU
My Ride: 530i
Engine: M54
Lord have mercy that's a lot of faults.
How old is your battery? My favorite one is "too little telegrams". maybe you need someone to send you more telegrams!
My Ride: 525i
Ha, yes! I need many more telegrams! Yes, it's lots of faults, but I think there's got to be one culprit. You mentioned "how old is my battery?" You are wise, Kyle .. just replaced it this morning with a brand new one, hooked up Carly, deleted the codes, then wham, back on.
Thanks to anyone with input/expertise!
My Ride: 530i
Engine: M54
you shouldnt need to replace your BST unless it is deployed, and even if it were deployed it shouldnt register all of those faults. I dont think BST is your problem. Are you sure the car has never been in a crash that resulted in SRS deployment? how long have you owned it?
You might want to bypass your IBS though, clear faults, see what that does for you. also you have an '04, check the trunk and make sure your MPM thats mounted to the floor is relocated to a high and dry spot.
My Ride: 525i
thanks, Kyle. Nope, never in a crash. The trunk and whole car is pristine, not a drop of liquid or even dirt anywhere. I have owned it for five years.
The dealer did replace the passenger seat mat recall work about a year ago. (I didn't have issues before they did it) -- I am wondering if that is the issue, maybe a second faulty seat mat?
I'd like to test by bypassing BST, clearing faults with Carly .. how do I bypass BST? I assume I connect what is connected to the BST directly to the battery? Appreciated.
My Ride: 530i
Engine: M54
you want to bypass IBS (intelligent battery sensor). there are plenty of tutorials out there for how to do it.
good luck, not sure if that'll solve your problems but it's free and certainly worth a shot.
My Ride: Sold: 545i, sport package, cold weather, 6MT
Engine: N62
loud068
12-19-2015 05:34 AM
