Sometimes alternator does not charge battery on startup
Old Jun 28, 2022 | 04:00 PM
habbyguy's Avatar
My Ride: 2006 530xi (Touring)
Be careful when doing ANYTHING in the engine compartment with a running engine (they can bite!) but there's no reason that moving the cables around would be a problem. The one possible exception is if the stud that connects the "big red wire" to the alternator is loose and jiggly, and then snaps off, leaving you with a direct connection to your battery floating around loose. ;-)
Old Jun 28, 2022 | 05:08 PM
donpb's Avatar
My Ride: '06 530i N52
Read the codes, you could have a failing IBS. Simply disconnecting the IBS won't magically solve your problem. The battery could already be ruined by the IBS.
Old Jun 28, 2022 | 11:52 PM
irlgabriel's Avatar
My Ride: e60 525d lci
Battery has less than 15k km on the car, IBS off for past 5k of those.
Old Jun 29, 2022 | 12:58 AM
donpb's Avatar
Doesn't matter. I had a brand-new battery go bad on me.
IBS acting up or not registering the battery can cause damage also.
Old Jun 29, 2022 | 04:11 AM
irlgabriel's Avatar
Originally Posted by habbyguy
Voltage changing is normal, though having it drop to 12 volts or below with the engine running isn't. ;-)
I just went through my E60 power management service document, and "it's more complicated" than I thought, with the DME being a pretty large part of the secret sauce that makes a BMW alternator wake up and start working (it contains the "programming" to tell it what to do). The IBS does provide some info, though I wouldn't swear it could cause the symptoms you're seeing. Is the IBS still unplugged?
I can send you the service document so you can get a feel for just how complicated BMW has made the charging / electrical load systems in these cars (kind of astonishing). The document is about 700kb in size (I think that's OK to send as an attachment in the messaging function here).
That said, the most common failure IS with an alternator, and my "wiggling cables" is still a very valid suggestion. If you can cause the symptom to cut in and out by moving a given cable, you're close to finding the culprit.
Cables wiggling helped, it is charging again!
Old Jun 29, 2022 | 07:12 AM
twh's Avatar
twh
My Ride: 2006 BMW 530xi 6MT
Engine: N52
That means there is a wire break or connector that is loose somehow.
Old Jun 29, 2022 | 08:17 AM
habbyguy's Avatar
Yep. I'd disconnect everything (after removing the "big red wire" connecting the battery to the engine compartment), clean the connections, and re-fit them. Otherwise, you're going to most likely have intermittent issues again in the future.
Old Jun 29, 2022 | 11:07 AM
donpb's Avatar
Since the IBS isn't connected, it is going to be random charging (open loop). You need to view the battery charge histogram in order to get an accurate assessment.
Old Jul 13, 2022 | 09:59 AM
irlgabriel's Avatar
Changed voltage regulator, everything is good now. Thanks everyone!
Old May 7, 2023 | 12:46 PM
Jurgens92's Avatar
My Ride: 320D e90 - M47
I have the exact same issue on my E90.
going to replace the voltage regulator, will confirm if it fixed the issue
thanks!
