Solving the PDC Failure errors
So my car started giving the PDC failure message. Spoke to BMW and they wouldn't even look at the car without charging me for a 'standard diagnostic scope'.
So I went through the normal drill.
1. Spray all PDC sensors with WD40 - nothing.
2. Check PDC control unit under the wheel well for damp - nothing.
3. Try to listen for PDC sensors making a clicking noise - nothing.
4. Luckily INPA has several options to check the PDC system. These screens showed me exactly which sensor was not reading anything. There are various screens and the one that was most useful showed each sensor in colours. These changed depending on the obstructions in front of the sensor. But it showed that only 1 rear sensor was gone, this goes against what others had written that the PDC Failure only occurs when 2 or more sensors are gone.
5. Biggest expense for me was the new sensor. Bought it brand new from BMW colour coded to my car. Ouch!
6. Only way to change the sensor was to remove the bumper.
The old sensor looked perfect in every way, yet when I replaced it the entire PDC system started working fine.
Without INPA I would have just been guessing and would have probably seen a massive bill from BMW.
Engine: N54
hmm. I have a sensor out but just get the "hole" in the display where that sensor shows nothing.
hopefully the whole thing won't quit working one day.
My Ride: 05 545i
Was it hard to change the sensor. I had one go out and same error message. BMW charged $378.oo to fix. Lucky still under warranty. 0 cost to me.
But mine was only one sensor causing the error, so that does show it only takes one to get to the PDC malfuntion error.
Hardest part it getting the bumper off to get to the sensor. But without INPA I would never have figured out which sensor was gone.
My Ride: E63
With Wd-40 cleaning it worked.When i turn the ignition on , I got Pdc failure on the dashboard even I did not put in reverse or press the Pdc button.Local service told me to repair costs for 130$.Thank you for your topic 👍🏻👍🏻👍🏻
xiTouring
08-17-2015 07:13 AM
