Software version... way to tell
Old Dec 29, 2008 | 02:34 PM
jagbagri's Avatar
Age old question:
I know there is no way to tell what software version you have other than by the dealer system.
But there must be some way you can tell visually ---
May be the way the iDrive looks, behaves, certain functions deferences between the newer and an older version.
Does anybody have any experience/insight with this sort?
Old Dec 29, 2008 | 03:40 PM
kgmccarthy's Avatar
Originally Posted by jagbagri' post='755402' date='Dec 29 2008, 06:34 PM
Age old question:
Actually, there is a way to check it indirectly via a hidden iDrive menu. The menu will actually give you a code called the "Target Data Status" which you can cross reference with the CIP version. Here is a good post (from another forum) that explains how to do it. Its a bit old, so it doesn't have all the latest cross reference information, but it should get you on the right track.
http://www.bimmerfest.com/forums/showthrea...light=drive+cip
Old Dec 29, 2008 | 04:54 PM
porsche911targa's Avatar
I've noticed that the start-up menu changed from mostly brown in the earlier version to mostly gray on the latest 31.2 upgrade.
Old Dec 29, 2008 | 04:59 PM
ktlocklear's Avatar
My Ride: '06 550i '84 Nissan S12 Turbo
Yeah......mine is now blue/ grey after the upgrade I got last month. They didn't tell what version it is....but the SA said it was the latest. I may have to try this route just for kicks to see what version it is
Old Dec 30, 2008 | 04:23 AM
Iceman's Avatar
My Ride: F02 LCI Individual
Model Year: 2013
Not really, unless you go through ALL hidden sub menus and check ALL codes.
Different modules, different codes.
When you perform the CIP/Progman update not ALL modules get updated.
Therefore, it is not a 100% guarantee to see the actual "correct" code. Maybe, if you're lucky.
The only way to really know what version the OS is: you have to get the info directly from your dealer!
Old Dec 30, 2008 | 05:27 AM
DD_545i's Avatar
Good to know. I plan to get mine upgraded within the next month. I'll make damn sure they tell me what I get.
Wonky
Apr 12, 2016 08:15 PM
wraduenz
Sep 25, 2015 07:40 PM
ucsbwsr
Sep 19, 2015 10:58 AM
mortyk
Sep 17, 2015 09:08 AM
Gadamsm5
E60 M5 Discussion
Sep 15, 2015 11:43 AM
