Software upgrade and TMC
Hi,
Just had the letest software installed with the recall here in the UK, and have noticed that TMC doesn't seem to perform as well as it did before, with the system reporting poor reception, and the TMC icon disapeering from the information bar at the bottom of the screen.
I have pro-nav by the way.
Anyone else noticed this? is there a fix?
Cheers
Rob
Cheers
Rob
Robbie
I can report EXACTLY the same problem as you.
I used to have v11.x and is performed the same way as now.
Then I moved to v12.x and the TMC performance was transformed. Signal came on instantaneously, perfect TMC reception all the time.
Now with v13.x it's crap again
Now, the question is - Is it something specifically to with TNC, or are the s/w updates doing something to the two radio tuners so that reception is not as sensitive?
BTW, if you want a workaround:- Tune specifically in to Classic FM. You will then find that TMC appears much more quickly (after a few seconds usually). Then you can go back and listen to what ever you had on before, CD, AM, different FM frequency etc.
Are you going to report it to the dealer? I would but I always feel as if I'm nagging.
Originally Posted by pharding' date='Nov 5 2004, 02:57 PM
What is TMC?
[snapback]52904[/snapback]
Browellm, yes I think i shall report it. I found the work-around by accident, but I find it a bit of a pain in the backside to tune it in like this, also, I don't like to interupt Terry Wogan in the mornings.....
I'll give it a week or so to monitor it in different locations etc.., then I'll call the dealer. I'll let you know how I get on.
[snapback]52929[/snapback]
I am just taken delivery of my new 525d - built in week 43 - and it too has the same problem. Also does any know how to make the Sat Nav repeat the last spoken instruction ?
thanks
jay
Originally Posted by sicce' date='Nov 5 2004, 10:15 AM
[quote name='Robbie' date='Nov 5 2004, 03:47 PM']Browellm, yes I think i shall report it. I found the work-around by accident, but I find it a bit of a pain in the backside to tune it in like this, also, I don't like to interupt Terry Wogan in the mornings.....
thanks
jay
[snapback]52931[/snapback]
[/quote]You can program one the steering wheel buttons to repeat last spoken instruction
