Software upgrade/New tires, and now my...
As I understand it, Dynamic Drive can be disabled through software just as Active Steering can. It may have been inadvertently turned off. I agree it is more likely the tires though.
I checked the tire pressure - it was set to specs (36/44 psi front/rear). I lowered each a few pounds, as I rarely have a full load, and it takes some of the edge off the harsh ride.
As for my original question, yes the new tires were probably a factor and things have improved after a few hundred miles. But doesn't the recent software upgrade also include revised active steering settings? If so, not sure I like 'em. <_<
Thanks for the input.
Originally Posted by TXPearl' date='Jun 12 2005, 03:47 PM
I checked the tire pressure - it was set to specs (36/44 psi front/rear).? I lowered each a few pounds, as I rarely have a full load, and it takes some of the edge off the harsh ride.
As for my original question, yes the new tires were probably a factor and things have improved after a few hundred miles.? But doesn't the recent software upgrade also include revised active steering settings?? If so, not sure I like 'em. <_<
[snapback]138871[/snapback]
tortuga
05-14-2015 11:51 AM
Faizd
04-27-2015 12:16 PM
