So im takin in the car for repairs
So im takin in my 545i in bmw to get my valve seals done tomorrow morning. Im pretty sure they know all the necessary repairs it needs done but im still a alil rusty in everything that needs done doin the valve seals can someone tell me what needs to be done while valves are gettin replaced. I heard the heads gotta be resurfaced?
Great time to get all of the oil leaks corrected with new gaskets throughout that area of the engine.
Also, I believe there is a coolant o-ring that fails and is a $1700 job for a $5 part (similar to the alternator bracket gasket dilemma but this one pertains to the coolant.) I would consider this one a must do since you're exposing the area where the o-ring resides.
Hey did you get the valve seals replaced? I might be headed in that direction as well. If you don't mind me asking, what did this cost? And were they able to do the job without removing the heads?
i wonder why though, that some people have valve seals that go bad. one possible cause for oil seeping through seals, is a blocked up crankcase ventilation valve.
Well its still at bmw its been there for almost aweek today and they said ill probably be gettin it back till the 15th. And he said it's a real long job costin me about 3900 parts and labor. I'm hoping they do take the heads off because I heard and I think ill call em and ask em to (wash the heads to get all that gunk off the valve). Anybody think that's necessary?
From what I've heard, the 545 suffers from severe carbon build up. So the heads must be removed and cleaned with tools since no solvent (i.e. Sea Foam) can remove it. These issues have been supposedly lessened in the 550 with the addition of the oil cooler, but we will have to wait and see as the mileage of 550's catches up with the 545.
Paran, the o-ring you mentioned for the valley coolant pipe is not a $5 part, typically they replace the entire pipe, which OEM costs around $12-1500 plus labor. There are replacement pipes out there for much less (around $900) but far from "cheap". The alternator bracket gasket is about $5, but it's a real PITA to replace.
That pipe does have a permanent seal on the front, so I guess that entire pipe is replaced, but the primary cost by far is in the labor which this owner is already paying since the top half of the engine has been removed.
Thanx H F I just called him and left him a vmail.. last time I talked to him was on thur or fri he said they would start opening her up today but I was really when you guys had my car for aweek and haven't opened her up???
