Snowy locations PHOTOSHOOT 2 - Night Edition
Old Dec 16, 2010 | 10:47 AM
  #31
xxrap985xx's Avatar
My Ride: 2005 545i Cold Weather Package Navigation and Logic7 Package Sport Suspension Package
Originally Posted by Anzafin
Well I think it is like any other budget class DSLR. Pros and cons are probably the same with many of them.
I chose the A300 above others because of these pros:
+ fast focusing
+ tilting screen
+ optical image stabilizer in its hull instead in the objective
These cons I've discovered during using it:
- higher ISOs are pretty unusable starting from ISO800 (I think this is the case with every budget class DSLR). Sure the luminous intensity of the objective has its effect too!
- it would be nice if the screen was turnable to left and right too instead of only up and down
I've also found the using of menus very easy. Sure if you get any camera, you'll learn its habits pretty soon.
- Antti -
thanks for the info....
i guess they dont make the a300 anymore so i was looking at the a390... what you think
BTW.. amamzing pictures.. hopefully i can start shooting like that...
Finland is very beautiful.. but i wouldnt be able to like a minute in those temps.. i complain when it is 20 F in New jersey.. i couldnt imagine -20F..lol
Old Dec 16, 2010 | 10:53 AM
  #32
Anzafin's Avatar
My Ride: Bmw 530d 2004
I'm sure you'll be happy with the A390 .
One particular advantage in these temperatures is that you can keep the car clean! Much cleaner than on summer. No dust, no water on the paint, just a breezing wind on it .
- Antti -
Old Dec 16, 2010 | 12:25 PM
  #33
mmitev's Avatar
looks like eric drew his self-portrait on your fender while you were not looking
Old Dec 16, 2010 | 12:32 PM
  #34
Anzafin's Avatar
Hahaha! Good eye !
That little bastard should be under surveillance 24/7 !
Old Dec 16, 2010 | 01:21 PM
  #35
orlovskyy's Avatar
sweet
Old Dec 16, 2010 | 05:34 PM
  #36
itb76's Avatar
My Ride: 2004 545i,1995 M3
Awesome pictures as ever!
Here in Michigan it's in the 20-30 Fahrenheit range, but it snows a lot so they salt and sand the roads. I could wash the car every day and not keep it clean!
Old Dec 17, 2010 | 01:40 PM
  #37
Anzafin's Avatar
I appreciate it, thanks .
We will get the most of snow not until February-March.
Old Dec 17, 2010 | 05:15 PM
  #38
Pennsy's Avatar
My Ride: 550i - Sport
Anzafin,
Do you have to use spacers on your car to mount those style 135 wheels? I went to mount a set with snows on my 550 today and was told I needed 20mm spacers to clear the front struts.
Thanks in advance,
-bill
Old Dec 17, 2010 | 10:07 PM
  #39
Anzafin's Avatar
Originally Posted by Pennsy
Anzafin,
Thanks in advance,
-bill
Hi Bill,
There are two different offsets/widths for the style 135 wheel;
- for 3 series cars there are: front 8x18 ET47 and rear 8,5x18 ET50 --> if you want to mount these into a 5er, you will need spacers to clear the struts
- for 5 series cars there; front + rear 8x18 ET20 --> no need for spacers.
However, if you want a flushed look in 5er with even the right wheel offsets (ET20), you will need spacers (New spacers for my winter setup ). But spacers are not needed to clear the struts, when using the right offset style 135 in a 5er .
- Antti -
Old Dec 18, 2010 | 11:23 AM
  #40
Pennsy's Avatar
Hi Bill,
- Antti -
Thanks for the reply - I stopped by today and picked up two of the A/S tires. The 20mm spacers arrived, so I should get the car back Monday. I can then see what offset they are - I am thinking ET20 X4. thanks again and enjoy the weekend....
